Question about Echo Gas Blower 135 MPH390 CFM Blower PB250
Whats going on with my pb 200 starts but wont stay running air filter is soaked with gas
  • 1,057 Answers
You probably have the needle in the carb not shutting off or going back to shut off the fuel. What you need to do is rebuild the carb and most lawn shops can sell you a kit to do that. You can see videos on as to how to do it if you are not familiar with the rebuild process it is not hard to accomplish. The kits are around $8.00. Hope this helps.
Posted on Oct 22, 2016
5 Suggested Answers
  • 148 Answers
SOURCE: I have a Echo PB/251 Gas Blower which I recently
Check the muffler and/or spark arrestor screen in the muffler outlet pipe and also the engine's exhaust port behind the muffler. These are prone to carbon-clogging and the engine cannot "BREATHE" enough to reach full throttle. If all-clear in the muffler, go back in the carb and locate the inlet screen directly opposite of the inlet needle. Carefully pull it out with a pick and hold it up to a light source. If you cannot see thru it, replace it. This is another, (less) common area of obstruction.
Hope this helps,
Posted on Oct 18, 2009
  • 31 Answers
SOURCE: my echo pb-2100 gas blower
no spark sounds like the coil, but check the connections and any corrossion in the wires
Posted on Oct 13, 2010
  • 285 Answers
You can't go wrong with 25:1. Common accepted best ratio for this item to give best life for the internal components.
Posted on Feb 14, 2011
  • 7482 Answers
SOURCE: PB 200 Echo only runs on full choke. Won't prime. I replaced everything in the carb and a new filter and lines. Getting air somewhere.
Hi dbooth
Make sure your fuel lines are connected correctly.
Check the drawing below
Please rate me
Posted on Oct 11, 2012
Echo pb 200 new carb, plug , filter , lines ,grommet starts and immediately dies
You might have the fuel lines crossed. Or a leak of air into the gas tank. It’s a fuel problem for sure if it starts and then dies.
Jan 20, 2018 | Echo Garden
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
Wont stay running, replaced spark plug and air filter, starts but wont stay running
Try mixing fresh gas mixture, any fuel over 30 days old is gone bad, this may help. Or the carburetor may need rebuilding, or the exhaust screen on the muffler is clogged up. Remember before taking anything apart use either PB blaster or Deep Creep on the bolts before loosening them.
Sep 24, 2009 | Echo Rapid Loader, Trimmer Head
Air Filter soaked with gas
Clean It with soap and water and afterwards let it dry and put a little bit of motor oil on the filter. You may want to check your petcocks because they may be leaking. Be cautious when you ride with a gas soaked air filter the airbox may catch on fire if the motorcycle backfires which I have experienced in the past.
Jun 26, 2009 | 2004 Honda VT 1100 C2 Shadow Sabre
Starts but wont stay running
Check your gas filter. When you ran out of gas, you got any rust in your lines and filters. Change the inline filter and use an air compressor and blow the line TOWARDS THE TANK. Take the gas cap off first. There is also a filter in your tank.By blowing the line you may unstop that filter.
Apr 03, 2009 | 1988 Ford Aerostar
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo Gas Blower 135 MPH390 CFM Blower PB250 Logo
148 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Are you an Echo Garden Expert? Answer questions, earn points and help others
