Question about Little Giant 4,280-GPH Dual Discharge Pump
How do you get the cover plate off to clean out accumulkated residue?
How to remove fusion glue from top plate
if the top plate is fabric covered I would guess you get a replacement cover if it is metal you can scrape it off then wipe with mineral spirits to get the residue off .
Nov 13, 2015 | Singer ESP2 Portable Steam Press
There is a black residue coming from the motor in the scent chamber. what could cause that/
Amanda:
The black residue is probably coming from the drive belt that goes from the motor to the beater bar. Lay the machine on it's back, and remove the foot plate (or cover plate for the belt) and check the belt for wear.
Feb 02, 2014 | Filter Queen Canister Vacuum Model 112C...
How do you run clean cycle - I have lost the manual
Self-Cleaning and Maintaining Sole Plate
Use the self-cleaning feature once a month by moving the steam lever back and forth from the "dry" setting several times. This will remove any residue from the steam valve and ensure that the steam system works properly.
Wipe the sole plate with a soft, damp cloth while the iron is cool and unplugged.
Run the iron over a cotton cloth several times to remove any residue from the sole plate.
Cleaning Anti-Calcium Feature
Fill the water cup that came with your iron. Use enough water to reach the Sunbeam logo in the top corner of the cup.
Add a teaspoon of salt to the cup and stir.
Empty the salt solution into the water reservoir in your iron.
Allow the iron to stand for 15 minutes, then empty out the water reservoir.Repeat this cycle with a second cupful of salt water.
Rinse out the reservoir with clean water. You should perform this cleaning once a month.
Jul 28, 2011 | Sunbeam Irons
Glasses are coming out clean but plastic has residue and the metal plates at the bottom of dishwasher and spin arm have residue as well. What could be causing this?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher isn't cleaning dishes as well as it should leaves a residue on plates etc
heatman101
Dec 29, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a 2005 gmc 2500 hd 6 liter. It has an oil leak that appears after being on the highway. It spray's up onto the firewall above the valve cover on the passenger side. The valve cover gasket has been...
there is a plate on back of the engine that can leak, but it will appear like the oil pan or rear main seal is leaking. you will need to clean any residue off and then check it out.
Dec 20, 2010 | GMC Sierra 2500HD Cars & Trucks
I need to clean my Eco Quest Living Air purifyer plate...
clean with 50/50 ammonia/water, scrub with toothbtush, clean contacts with q-tip
Mar 01, 2009 | Ecoquest Breeze AT Living Air Purifier
Ecoquest fresh air repair
Regardless of unit the purifier plates may need replacement. How are the plates cleaned? Could it be that there is a residue from the cleaning agent present after cleaning? With new plates there is a little oil on the plates to prevent oxidation when in storage or transit. A little rubbing alcohol would do the trick.
Make sure the plates are dry before putting them back into the unit.
If the plates are seated right and clean you should see a faint purple glow on the plates when the unit is on purify.
Let me know if that's the case.
Eric
Dec 18, 2008 | Ecoquest Fresh Air Air Purifier
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Nov 17, 2008 | Dishwashers
Little Giant 4,280-GPH Dual Discharge Pump Logo
23 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
