Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deere tractor starting,bogs down then dies
I forgot to mention this tractor does'nt have a carburator.We changed the fuel injectors about 5 years ago would this possibly be the problem again? I took the line off the fuel injector but not a lot of fuel going through it. It's a 1020. Thanks for any help.
    Sniper:
  • 197 Answers
Send your injectors in to be bench tested.They should pop around 2300 psi.I could be wrong about pressure scince I havent bench tested this model injector in some time.Takes about 5 minutes for all of them.Also see if your primer pump has good pressure,
Posted on Nov 14, 2009
    Problem Solver:
  • 7 Answers
Check fuel lines for restriction
Posted on Jun 25, 2009
Our mower starts and idles fine but as you increase the revs it starts to back fire and the engine dies, what can we do to fix this? We have cleaned the carbureator, and replaced the fuel pump.
this indicates a problem ignition module
try a replacement unit before you get a new one or have the existing unit checked at a mower shop
Oct 27, 2016 | John Deere Garden
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
1970 John Deere 4020 Diesel, Engine speeds up by its self, I goose the throttle and then it will idle down. pretty sure it is a govenor problem. How do I fix this?
spring is broken/stretched out on govenor linkage bar that runs from air damper flag to injector pump and i would expect a 1970 to be needing a new spring about 5 years ago
Dec 12, 2013 | John Deere Steel Chain/farm/tractor/john...
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
John Deere weed eater problems
remove the muffler and run it if it runs good after that open the muffler and clean the screen inside
Apr 01, 2012 | Garden
I have a john deere gx85, i have been using it all year and had no issues until recently. it runs strong for about 5 minutes then all of a sudden dies and sounds like it chokes itself out. i cleaned air...
A buddy of mine had this problem. He said there is a line running from the carb down to the crankcase. I don't know if a valve quit working in the carb or what...basically after he shut it off, it was draining fuel into the crankcase. Obviously he changed the oil, and started shutting off the fuel valve after he mows with it. No problems since.
I imagine the problem could be solved with a carb rebuild as well.
Oct 21, 2010 | John Deere Garden
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere tractor won't stay running
Its using up the gas in the carb then it stalls. take the carb off and clean it and make sure the float in the bulb of the carb isnt sticking closed.
Jun 22, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
481 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
