Question about Santa Fe Dehumidifiers
Makes grinding sound
Just turned it on and its making loud grinding sound that it never did before what does that mean
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
Motor loud
if it is the fan, the bearings are shot. replace it. if it is the compressor, you can't fix it. you've been had.
May 02, 2012 | Danby Dehumidifiers
T he compresser on my dehumidifier is loud, why is that.the fan that runs is guiet but when the compresser turns on it sounds like it is vibrating
It may not be setting on a level floor or the hardwood flooring or tile flooring is allowing it to vibrate more than it normally should. Also, remove the air intake filter to make sure it's clean.
Hope this helped you, Kathy. Please let me know. Thanks.
Jul 13, 2011 | LG LHD459EL Dehumidifier
Comfort Aire BHD 651. When I turn it on it makes a grinding sound that continues. I have cleaned the filter and vacuumed all accessible areas.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 09, 2011 | Comfort-Aire Dehumidifiers
Engine is making notice
The compressor is a mechanical pump that will be loud...plus the fan has to move air to make it work correctly...not much you can do about it...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 03, 2010 | LG Goldstar LD65EL Dehumidifier
Loud Vibration
Check the front water bucket handle.
Sep 10, 2008 | Haier Dehumidifiers
Unbearable noise
Mine does the same thing, for the third time. Seems the plastic fan on mine, lasts a little over a year. Not hard to change, just a bad design on the part. I'm ordering an extra tis time, to save on freight.
Sep 05, 2008 | Fedders A7DH65B2A Dehumidifier
Noise vibrations in dehumidifer
sounds like a sealed system issue it has a 5 yr. warrenty on the sealed system, cost to repair might mean an new one instead
May 03, 2008 | Dehumidifiers
Makes a loud noise
not sure which dehum yo have,but here I go! most fans are not part of the cooling system. first remove the housing where the fan is. turn the unit on and check to see if the fan is turning. if not then just wait till you hear the compressor kick in. if the compressor goes on then you do have a problem w/the fan motor and it will have to be replaced. worst comes to worst just bring it into Sears. they have techs which will let you know what the exact problem is and you can take it from there. make sure you give them the model # first,just to check if the have parts for your dehum.
Dec 18, 2007 | Eva-Dry EVD1100 Reable Petite Dehumidifier...
Dehumidifiers Logo
Top Santa Fe Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Santa Fe Dehumidifier Expert? Answer questions, earn points and help others
