Question about Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower
Just stopped after thick grass
Just stopped the engine. Is there a reset button?
When I run into a lil thick patch of grass my husqvarna iz 5223 motor will die down & the blades almost stop. I was told that it might be the clutch.
It may also be the belt. Over time the belt stretchs and needs replaced. Additionally and depending on grass height a bigger horsepower engine is the answer. I changed my engine to a lager horsepower and never have this problem anymore
Jul 23, 2015 | Husqvarna Garden
Why does my weed eater stall
It may stall for many reasons. Is the frass too tall, too thick or the stems are too solid? The whipper can cut most grasses but some are hard grasses that put considerable pressure on the machine that it locks the spinning string feed, therefore stopping it. Other reasons are due to the type of fuel (fixing inconsistencies, too much or too little oil in the fuel or the fuel has been left out for too long and is somewhat a little exhausted. You note this by hard starting. The engine could be labouring because it's not tuned properly. Try starting it and do a manual tune-up. See it stays running at idle and then do some accellerations before it is taken out to cut grasses.
Aug 12, 2014 | Garden
Engine boggs down in thick grass
are the blades sharp?hows the fuel and air filters?is the gas newer than 30 days?when was the last time the oil was changed?
Aug 15, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Have 18.5hp briggs&straton and slows down in thick grass
its possible that the spring tension from the governor to the throttle linkage is weak
Jul 06, 2012 | Garden
Blade slows down when grass gets thick
The reason the blade slows down when the grass gets thick is simply because the mechanism operating the blade is weak and cannot move fast when on thick grass.
I suggest you troubleshoot the mower. After that, the blade should work fine when the grass gets thick.
Also, some mowers normally gets slow when grass gets thick, so after troubleshooting, if the mower does the same, then you already know it has to be slow when trying to cut thick grasses.
Take care
Sep 09, 2010 | Toro Personal Pace CARB Walk Power Mower
Was running, hit a rock and now it won't start. grass was wet too
My guess is that the sudden stop has sheared the key that makes the flywheel turn with the crankshaft. (the key is a little sliver of metal that bridges a pair of slots cut into the end of the shaft and the bore of the flywheel. The flywheel is the large metal wheel that spins round on the top of the engine). Since the ignition timing is driven by the position of the flywheel, this does tend to stop the engine working.
The end of the shaft is usually tapered, making the flywheel a tight fit. Conequently, you will need a tool called a "puller" to get it off to put a new key in. Trying to hammer it off instead will just damage the magnets on the flywheel and make matters worse, so don't be tempted.
A
May 16, 2010 | Mtd 22" Yard Machine Push Mower
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
