Run ups without cooling fan - Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
You give little information, can you tell us more?
If the UPS is in a sufficiently cold room it can last without a fan.
But better is if you use a UPS Line Interactive mode fashion.
It is quiet until it starts working.
Posted on Jan 26, 2015
My 2004 3400 closed system ,runs hot in town unless heater is on. driving up a mountain pass it gets very hot.on a flat highway runs normal. new t state,resivior cap, both fans work no leaks or smell
Radiator fan motor or radiator fan thermostat defective/
Also there is a relay that operates the fan motor
In town not enough air passing through radiator allowing it to over temp.. With heater fan running acts like cooling fan keeping engine cool
Highway driving ample air passing through radiator without fan.
Hill climbing requires cooling fan/
Hope this helps?
Nov 17, 2016 | Cars & Trucks
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
How did you know when the cooling fans are not working
You may have one conventional belt-driven fan with a thermal clutch and the other electric or, both could be electric on your car.
The cooling fan that operates during non-AC operation (just a running engine) if electric, will be controlled by a thermal switch in the lower radiator tank and may not turn on at all unless the engine is warmed up. The belt-driven fan should be turning at some speed all the time if the engine is running and at much higher speed with a hot engine.
The fan that cools mostly when the AC is operating won't run under normal operation but may turn on in hot weather (or when the engine is under heavier loads) even without the AC operating.
Checking them would require having a warmed-up engine and the AC turned on. Both fans regardless of type should be turning then.
Jun 03, 2011 | 2000 Mercury Cougar
Cooling fan won't shut off
Hi!
Check the cooling fan Relay located on the engine compartment Fuse n Relay Box, it is probably stuck ON. If fan stops when relay is removed, replace relay.
Note: Some vehicles are equipped with automatic cooling fans where the cooling fan can come on when engine is hot, even if the key is OFF or not in the Ignition, check your owners manual.
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 09, 2011 | 2004 Chevrolet Cavalier
Do both cooling fans run at the same time, or are they staged?
One cooling fan runs when the engine reaches a certain temp. The second cooling fan is designed to run when the a/c is turned on, providing more air flow throw radiator. However, it will cause no harm or damage if both fans run at the same time, with or without the a/c turned on.
Jul 13, 2010 | 1993 Oldsmobile Cutlass Supreme
Cooling fans are running for a long time and still
If the fans are running long after the car is shut off, the fan relay is fused together. Unplug the cooling fan relay and get a new one. Don't drive it far without that relay though. Put it back in and drive to your supplier.
Aug 16, 2009 | 2002 Ford Windstar Cargo
Outdoor fan is running continuously without using Wireless Remote Controller
Bad control board on the condensing unit up top. The board needs to be replaced as it is sending the message that the system is calling for cooling/heating all the time and doesnt know what to do. If you continue to let it run this way you will ed up having more major issues
Jun 01, 2009 | Fujitsu Heating & Cooling
Engine fan doesn't run with or without ac
Check the cooling fan switch/ cooling fan control. as their job is to monitor temp. of engine, and turn the cooling fan on and off.
Dec 30, 2008 | 1997 Chevrolet Monte Carlo
DELL DIMENSIONS 2300 COOLING FAN
Your system will run fine until the processor starts overheating... why not just replace the fan?
Oct 26, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
