Question about GE GSS25JF Side by Side Refrigerator
How do you initiate a defrost cycle in a GE Ref GSS22JF (computer
It is computerized, not timed defrost
  • 351 Answers
Nope not them models, i would just change the board, and to bypass the board you have to be a service man with a computer and equipment.
Posted on Jun 23, 2009
GE model gth16dberww top mount freezer. Freezer is iced over. Removed rear cover and coils are also iced over. Poured warm water into drain and water immediately exited to drip pan. not sure where to
Sounds like the defrost timer is not functioning, or a defrost element is burnt out.
#1. After an accumulative "run time", typically the timer will initiate a defrost cycle. At that point the defrost heaters are energized and the compressor is turned off for the duration of the cycle. The defrost time cycle varies from manufacturer to manufacturer and can be as low as 15 minutes to as much as a half hour. If it is defective, it could be stuck in the cooling position not initiating a defrost function.
#2. If the defrost heater element is burnt out, the timer functions normally and will cycle the defective heater on, but there will be no heat generated to defrost the ice.
#3. A more remote possibility is a defective "defrost termination thermostat" which is wired in series with the defrost element. If defective, it will keep the element from energizing on a call for defrost.
At any rate, unless you are extremely handy AND have access to a supplier of repair parts, it sounds like a service tech needs to be called.
Oct 17, 2014 | GE Refrigerators
GE GSS22JF not cooling both freezer and frigerator. Steps to try to figure out problem
open the freezer door,from the bottom up remove the second draw or bin and touch the back wall to see if there's like snow or ice on the back wall,if so you have a defrost problem,with a meter check the heater and the thermostat,if no ice then you have a bad computer board located on the back outside wall of the machine part number wr55x10942.let me know what you find
Sep 26, 2010 | GE GSS22JF Side by Side Refrigerator
REF WONT GO INTO DEF
Your problem may be with the "defrost timer" (should be located in the fresh food compartment). Typically, refrigerators have approximately 8 hours of refrigeration cycle, then approximately 30 minutes of defrost cycle. The defrost timer controls each cycle.
Contact an appliance service company.
Feb 16, 2010 | GE Refrigerators
Evaporator fan works sometimes
by the sound of it , i would get a new evap fan,
as the power to the fan is switching on - thats why
you can flick it and get it running, the power is there.
it is a common problem with evap fans.
Dec 12, 2009 | GE GSS22JF Side by Side Refrigerator
I have a GE side by side ref. model # GSS22JFMC WW that is not cooling. A few months ago I replaced the defrosting element. It is not freezing up but for some reason it sometimes stops cooling. I can turn...
First this refrigerator has very low consumer rating. They are plagued with problems with very poor company backing. But without be able to diagnosis the problem in person I would say it's the mother board. And you may find that GE has a new updated board for your appliance. I would go to Amazon.com and search for your motherboard for your refrigerator and read the reviews. Some people leave some great idea. Plus it you bought this refrigerator brand new you can fight with GE to send you a new board.
Oct 29, 2017 | GE GSS22JF Side by Side Refrigerator
Loud noise from GE Side by Side
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 07, 2009 | GE GSS22JF Side by Side Refrigerator
Side by side gss22jf,fridge at 50 degrees
A quick stop at my local appliance store with some info for the tech.
and It was clear that the problem was in the evaporator(freezer)
section. turns out the defrost element($40.00) was the culprit.
It was so easy to change. Please be certain to unplug the refridge if you try this at home. This sure beats spending another $1,000.00 on a new
fridge. Good Luck
Sep 13, 2009 | GE Refrigerators
I have replaced motherboard and defrost still is not coming on.
Your defrost timer may be completely out. We have parts if you trust us! We are HONEST! Hope this helps. Ella
Aug 18, 2009 | Refrigerators
Fridge/freezer inoperative
does your fan work in the back of the unit. Either that or it could have been your compressor
Dec 23, 2008 | GE GSS22JF Side by Side Refrigerator
GE GSS25JF Side by Side Refrigerator Logo
229 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
