Question about Akai LCT3201AD 32 in. LCD Television
What is the code number of remote for ct-20mn mkiii ?
Color prolume in Akai CT-20MN MK iii
What is the problem with color to your set? Provide more details, please. Check its system settings too; like PAL, NTSC, SECAM etc. Gopakumar Gopalan Google
May 03, 2014 | Akai CTS2550 25" TV
Won''t turn on the tv also cannot change the settings manually on the tv
Thanks for stopping by.
What is the model number and manufacturer of the TV you are trying to control with the CT-90157 remote?
Not all IR codes are programmed into all remotes.
Sep 26, 2011 | Toshiba CT-90157 Remote Control
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
Need panasonic tv remote code to program my philipsuniversal remote control
model number of your emote should be under the battery lid. Search google for
universal remote codes your_model_remote
Remote should come with a sheet containing the codes. If yours is not on there, contact the 800 number for the remote manufacturer.
HTH
Apr 23, 2010 | Panasonic CT-32SL14 32" TV
Codes for toshiba universal remote number ct-90302
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Mar 26, 2010 | Toshiba CT-90157 Remote Control
Toshiba CT-877 Remote
http://remotes.com/remotes/documents/Toshiba/CT-877.pdf
Jan 06, 2009 | Toshiba CT-90157 Remote Control
Akai LCT3201AD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
