Question about 9gag.com Computers & Internet
9GAG Gif loading slowness problem
3 or 4 months ago gifs loading was really fast. Bu recent days when i try to play any gif it takes so long time to load it. My internet speed is fine 50mbps download - 20 mbps upload
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
If the same problem occurs in your mobile using the 9gag app, then you don't have 50mbps connection.
Posted on Oct 11, 2014
4 Suggested Answers
SOURCE: Hi sir i did as you said to get transparent file
Take the png pict in PhotoShop or a similar tool so you can remove edges, make a layered image without the beckground and save it as transparent.
Posted on Mar 23, 2009
Blackberry_U
  • 223 Answers
SOURCE: slow slow slow...! it takes eges to load the facebook page
The problem probably lies with facebook and not your connection. Try in a few days...
Posted on Jun 01, 2009
damneddle
  • 1607 Answers
SOURCE: how to upload a GIF
Facebook doesn't allow animated GIF. You can upload a gif format file in Facebook just like the way you upload jpeg pictures.. BUT it will not be moving/animated.
Posted on Jun 15, 2011
How do you upload an animated gif in 9gag?
9gag.com/gag/18478/baby-instructions-all
Not sure of the above.
Jun 17, 2014 | 9gag.com
Looking for a 2.2 ecotec timing chain diagram with pictures
Getting the timing chain back on these engines can be tricky and requires more than just a diagram to get right. Here is how the timing chain should be reinstalled. Keep in mind that this engine can cause damage to the valves if the timing chain has any problems while the engine is running so it may not be a bad idea to setup the timing system as follows and do a compression test to make sure that everything is in order there.
Install the crankshaft sprocket with timing mark at the 5 o'clock position. Lower the timing chain through the opening in the top of the cylinder head. Carefully ensure that the chain goes around both sides of the cylinder block bosses (See 1 & 2 in picture): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412535.gif
Install the intake camshaft sprocket with the INT diamond at the 2 o'clock position. Hand tighten a NEW intake camshaft sprocket bolt. Route the timing chain around the crankshaft sprocket with the matching colored link aligning with the timing mark. Route the timing chain around the intake camshaft sprocket with the uniquely colored link (1) aligning with the INT diamond: http://gsi.xw.gm.com/image_en_us/gif/000/000/466/466558.gif
Install the timing chain tensioner guide through the opening in the top of the cylinder head. Tighten the timing chain tensioner guide bolt to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412160.gif
Install the exhaust camshaft sprocket with the timing chain matching colored link (3) at EXH triangle aligned at the 10 o'clock position: http://gsi.xw.gm.com/image_en_us/gif/000/000/466/466570.gif
Ensure the timing marks and the colored links (1,2,3) are correctly aligned: http://gsi.xw.gm.com/image_en_us/gif/000/002/003/2003412.gif
Use a 24 mm wrench to rotate the camshaft slightly, until exhaust sprocket aligns with the camshaft. Hand tighten the NEW exhaust camshaft sprocket bolt: http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412536.gif
Install the fixed timing chain guide. Tighten the fixed timing chain bolts to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412165.gif
Apply sealant, GM P/N 12378521 (Canadian P/N 88901148) compound to thread and install the timing chain guide bolt access hole plug. Tighten the chain guide plug to 90 N·m (66 lb ft): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412164.gif
Install the timing chain upper guide. Tighten the timing chain upper guide bolts to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412167.gif
Inspect the timing chain tensioner. If the timing chain tensioner, O-ring seal, or washer is damaged, replace the timing chain tensioner. Measure the timing chain tensioner assembly from end to end. A new tensioner should be supplied in the fully compressed non-active state. A tensioner in the compressed state will measure 72 mm (2.83 in) (a) from end to end. A tensioner in the active state will measure 85 mm (3.35 in) (a) from end to end.
****If the timing chain tensioner is not in the compressed state, perform the following steps. Remove the piston assembly from the body of the timing chain tensioner by pulling it out. Set the J 45027-2 (2) into a vise. Install the notch end of the piston assembly into the J 45027-2 (2). Using the J 45027-1 (1), turn the ratchet cylinder into the piston: http://gsi.xw.gm.com/image_en_us/gif/000/000/797/797246.gif
Inspect the bore of the tensioner body for dirt, debris, and damage. If any damage appears, replace the tensioner. Clean dirt or debris out with a lint free cloth. Install the compressed piston assembly back into the timing chain tensioner body until it stops at the bottom of the bore. Do not compress the piston assembly against the bottom of the bore. If the piston assembly is compressed against the bottom of the bore, it will activate the tensioner, which will then need to be reset again. At this point the tensioner should measure approximately 72 mm (2.83 in) (a) from end to end. If the tensioner does not read 72 mm (2.83 in) (a) from end to end repeat the steps required to return it to it's compressed state above.
Install the timing chain tensioner. Tighten the timing chain tensioner to 75 N·m (55 lb ft). Use a suitable tool with a rubber tip on the end. Feed the tool down through the camshaft drive chant to rest on the timing chain. Then give a sharp jolt diagonally downwards to release the tensioner: http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412158.gif
Use a 24 mm wrench to hold the camshaft. Tighten the NEW camshaft bolts to 85 N·m (63 lb ft) plus 30 degrees: http://gsi.xw.gm.com/image_en_us/gif/000/000/630/630311.gif
May 25, 2011 | 2002 Pontiac Grand Am
Gif file
If the .gif file is stored in memory card,then format it after taking back up.
Aug 12, 2009 | HTC G1
All in one Cannon Pixma MX860 inkjet
None go to : tp://www.usa.canon.com/consumer/controller
for support: Tech Support spacer.gif spacer.gif red_arrow_greybk.gif Frequently Asked Questions red_arrow_greybk.gif Support by E-mail red_arrow_greybk.gif Support by Phone
Jun 26, 2009 | Office Equipment & Supplies
Already have a lexmark x4270. can't recieve a fax?
Chances are you'll find your problem under 'fax settings' or a similarly titled option on the display. If you have it hooked up a computer as well you're in luck, most come with software that has an option labeled 'fax setup wizard' or something similar. Just follow the steps in that or call customer support at the following link to be walked through every step.
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:439:0:0
Lexmark Customer Support: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-332-4120cb_transparent_r.gif
Change headlight
hello. below is the procedure for removal of the headlamp for bulb replacement. to access the headlamp you will need to remove the bumper fascia. http://gsi.xw.gm.com/image_en_us/gif/000/001/725/1725371.gif Callout Component Name 1 Front Compartment Sight Shield Plastic Retainers (Qty: 6) 2 Front Compartment Sight Shields (Qty: 3) Tip Each front compartment sight shield is serviced separately as needed for repairs http://gsi.xw.gm.com/image_en_us/gif/000/001/728/1728611.gif Callout Component Name Preliminary Procedure Remove the front wheelhouse liner. Refer to Front Wheelhouse Liner Replacement . 1 Front Fascia Extension Plastic Retainers (Qty: 5) 2 Front Fascia Extension http://gsi.xw.gm.com/image_en_us/gif/000/001/733/1733942.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedures Remove the front compartment sight shields. Remove both front bumper fascia extensions. 1 Front Bumper Fascia Reinforcement Nut (Qty: 2) Tighten 6 N·m (53 lb in) 2 Front Bumper Fascia http://gsi.xw.gm.com/image_en_us/gif/000/001/736/1736893.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedure Remove the front bumper fascia. 1 Headlamp Nut (Qty: 1) Tighten 6 N·m (53 lb in) 2 Headlamp Bolts (Qty: 3) Tighten 6 N·m (53 lb in) 3 Headlamp Assembly
Jun 13, 2009 | 2003 Cadillac CTS
My son passed away two weeks ago and I'm trying to get his phone unlocked so I can maybe get some closure as to what was going on that could have led to his death. He was only 18. Teen mobile will not help...
I don't know if this will work. I just found it on this site. Good luck and sorry for your loss.
In order to hard reset the sidekick u have to take the battery cover off when it is off press and hold the {R} letter and take the battery out while still holding {R}, count 4 seconds and place the battery back into the phone while still holding {R}. If this was done right then right then you should see the phone restarting and when it is fully powered on then u should see that the phone lock is completely removed and the phone is not blocked at all
Mar 24, 2009 | Nokia N70 Cellular Phone
ASUS m2n32 won't allow me to go into setup; shuts down...
Try to reset your BIOS by removing the button cell located at your motherboard and put it back. Check the SATA connector of your hard drive and make sure it fits right. Boot the machine and set-up to "boot from CR-ROM". And install new WINDOWS XP.
Jan 04, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Sidekick i.d
report.gifTry this............................................................. 1. Get to the screen where you would normally type in the 3-digit privacy lock code
2.Hold key-menu.gif + key-jump.gif to get to the Emergency Phone Call screen
3. Hold key-jump.gif + + s which takes you to the SYSLOG screen
4. From there press key-done.gif, key-jump.gif, or key-cancel.gif and you're in!
Dec 06, 2007 | T-Mobile Sidekick ID Cellular Phone
Computers & Internet Logo
104 people viewed this question
Top 9gag.com Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a 9gag.com Computer and Internet Expert? Answer questions, earn points and help others
