Question about Nintendo DS Lite Console
Ds lite not working
Ds lite hs no power at all ,its not that old either no visible damage
    Problem Solver:
  • 9 Answers
I would take it back to the store, sounds like a generic fault.
Posted on Jun 23, 2009
DS won't turn on
Hi Atticus,
I have seen this happen when someone plugs the wrong charging cord up to the DS lite, Is there any chance some one did this to your DS lite.It sounds also as if the battery is not making proper connection.
  1. REmove the battery from the compartment
  2. inspect the connector on the battery and where the battery connects to the DSlite.
  3. Wipe thee connections off some way. I suggest some contact cleaner for bith the battery and Battery compartment connections
  4. Try the DS lite again with the battery installed.
I hope this gets you in business  Atticus. Do not Vote until we get it working.  Try this and add a comment to this problem posting. I will answer as soon as I possibly can. Thank you very much for the opportunity to solve your porblem with a DS Lite.
Oct 18, 2007 | Nintendo DS Lite Console
Tip
DS Lite fuse replacement F1 F2
Does your DS lite refuse to charge?
Does the orange charge light not come on at all?
Has your DS stopped switching on with no green light at all?
Well this is the guide for you.
Remove the DS lites base plate (for a guide on how to do this see my other tips and tricks) and locate F1 and F2 (see pics)
F1- Charging fuse. Change this one if you have the following issue:
Orange light doesn't come on at all when the charger is inserted and a battery connected.
F2- Console power fuse. Change this one if you have the following issue:
The DS lite console charges but refuses to power on.
If you find that the DS lite console neither charges or switches on i.e. no lights come on, not even for a brief time you can replace both fuses and it "should" resolve the issues, however, I cannot guarantee this as there could be other factors for the lack of power e.g. water damage.
To change a fuse you need to first remove the old one, do this by desoldering either side of itand remove it from the board.
Putting the new fuse on is a little trickier, you will need to hold the fuse in place with a small enough item that will not get in the way ofthe soldering process such as a cocktail stick or tweezers. Solder either side of the fuse to the board taking care not to make a bridge* with the solder. Give your newly laid fuse a test to be sure you have done it correctly, put the DS lite back together and then your done.
*Bridge - A solid connection made over or around the fuse thus bypassing it.
I hope this helps and I have to say that I take no responsability for any damage that may occur whilst following my tips/ guides.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
The bottom screen of my nintendo ds lite is shaking constantly.
Make shure that it hs not been droped oris shook if it has then reset the whole system and let sit for 30 minutes
Dec 17, 2010 | Nintendo DS Lite Console
DS Lite restarting itself
It maybe that you dont charge it?? The game card may have been damaged not sure... you might have touched the power sliding thing... Try and leave your DS on for a few minutes and see if it turns off.
Mar 21, 2008 | Nintendo DS Lite Console
Ds lite not starting
either your battery is out of use or damaged or circuit board has obtained physical damage
Mar 16, 2008 | Nintendo DS Lite Console
Power button loosely slides
Yes. The switch has broken and is replaceable. However I wouldn't recommend you do it unless you've done this before. DS Lites are easy to damage further when taking them apart. It's a great system but is easily broken beyond fixing. Look at all the posts on here from people putting new shells on and now the system won't boot up, broken ribbon cable connectors, etc. If it's under a year old contact Nintendo and they will repair it for free.
Mar 08, 2008 | Nintendo DS Lite Console
DS lite not working
there may be some kind of damage in the ds as i had the same problem it may have been shaken around or dropped or even faulty the best thing to do is send it back if you dont have the warranty then go to a gaming store most have a collection day where someone comes to pick up broken ds and takes them its free except tfor the repair.Its best if you dont fiddle around with it a it will become more damaged
Jan 05, 2008 | Nintendo DS Lite Console
Ds lite
Components may have come loose on the board, or damaged solder joints. Water damage can sometimes only appear after water has had time to seep, unless knock helped throw some residual water around inside, onto things it shouldn't touch.
Dec 02, 2007 | Nintendo DS Lite Console
DS Lite does not power up
If the console has overcharged or has been used for long periods of time or could just be fluke, chances are the fuses are blown on the main motherboard try this link, this guy fixed my ds and i had the exact same problems as you guys have
Sep 10, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
