Question about Akai LCT3201AD 32 in. LCD Television
What is the remote ct-20mn mk111 ninja 20? my remote is mising.how can i select a new remote?.................................................................../?
Button to scan in channels
The CT-90326 remote was included with several Toshiba televisions, including the 42HL800A. You can't directly scan for channels with a single button on the remote. First make sure that the TV is set to the TV input. (Use the Input button on the remote (top left) or the TV (lowest button on the left side as you face the screen).) Next press Menu (the second lowest button on the TV or the button at the lower left of the Left arrow button). Use the Left or Right arrows to select Setup (with the gear icon) and press OK. Use the Up/Down arrows to select Auto-Tuning and press OK. Use the Up/Down arrows to reach the line to select the type of channels to search for a signal. Then use the Left/Right arrows to select Digital channels, Analog channels or both. Go down another line to set the bandwidth of your broadcasts. Again use the Left/Right arrows to select the correct one. Go down one more line to Start Scan and press OK.
These details are in the manual for your TV. The manual for the 42HL800A is available from Toshiba's product support download page: http://www.mytoshiba.com.au/support/televisions/led-backlit-tv/hl800a/42hl800a/download . The direct link to the manual is http://www.mytoshiba.com.au/file/download/resource/file/19610/toshiba_32av80032%2040lv80026%2032el80032%2042hl800_om%20(au).pdf .
I hope this helps.
Oct 02, 2016 | Toshiba CT-90326 Remote Control
Color prolume in Akai CT-20MN MK iii
What is the problem with color to your set? Provide more details, please. Check its system settings too; like PAL, NTSC, SECAM etc. Gopakumar Gopalan Google
May 03, 2014 | Akai CTS2550 25" TV
Is it posible to program my Centurion D3 remotes to open an E.T MK111 garage door motor
No. It's not possible. There is no setup codes to synchronize with.
Nov 27, 2013 | Televison & Video
Remote control won't work, working yesterday. had to manually turn on and change channel, put in new batteries today
If the remote is a universal remote (multifunction) check the buttons at the top of the remote if one is labbeled "TV" press that one first and then try the TV
Sep 26, 2009 | Panasonic CT-20G8 20" TV
How to unlock AV on hotel tv philips HT5504/01Z?
mon tv mise en vielle apres toutes les 15 minutes
Aug 30, 2009 | Philips 20PT6441 20" TV
Can't program my Toshiba CT-90302 remote to my DirecTV reciever?
step 1, select the funtion you wish to program on left side.
step 2 hold down the recall button while entering the 3 digit code for the device you wish to program
step 3 have a beer, you are done
Here is the link for the owner's manual that also has the codes
http://remotes.com/remotes/documents/Toshiba/CT-90157.pdf
Jan 22, 2009 | Toshiba CT-90157 Remote Control
I can't program my Toshiba TV to the CT 91507 remote
change battrries and select our old remote control codes
Jan 19, 2009 | Toshiba CT-90157 Remote Control
Remote control
Did you try universal remote control. Are you sure remote control is good. http://www.retrevo.com/support/Panasonic-CT-20SX12D-TVs-manual/id/274ci956/t/2/
You can order in www.tritronicsinc.com Thank you
Aug 13, 2008 | Panasonic CT-20SX12D 20" TV
Akai LCT3201AD 32 in. LCD Television Logo
18 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
