Question about Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
Why akai tv won't turn on? - Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
I have the pth5498 and my tv won't turn on. My
Timer is not the problem---the tick ticking sound is the shutdown circuit in the set that has been triggered by a short somewhere likely in the high voltage area or the convergence circuit---shop repair---says Akai but I suspect set was made by Samsung who owned that name at one time.
May 25, 2012 | Akai Televison & Video
Tv won't turn on after power failure
Hi.Please check the fuse of your television.Try to remove the back cover of the TV and find the fuse its located at the back of the board near the ac cord connection to the board then replace the same value of fuse.
Jul 05, 2011 | Akai LCT2070 20 in. EDTV-Ready LCD...
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
My Akai LCD TV/Dvd player will not turn on
http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Jun 17, 2009 | Akai LCT2721AD 27 in. LCD Television
Tv wont turn on
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3785TA POWER SUPPLY BOARD MLT386X
Oct 02, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Akai LCT 32"
Do you still have this TV?Sounds to me like a bad capacitor,or two.I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Jan 03, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
TV problem
take your tv to a tech your power supply is faulty or the xray protection circuit.good luck.
May 06, 2007 | Akai LCT3215/26 32 in. LCD Television
Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2 Logo
62 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
