Question about Dell A525 Zylux Multimedia Computer Pc Speaker System W/subwoofer 2.1
Is this speakers active ?
Left and right speakers
Right monitor has stopped working, left still works
Electrical parts were bad, I returned the speakers for replacement under warranty. FYI... I opened the back and noticed an electrical burn smell.
May 06, 2014 | Alesis M1 Active 320 USB Speakers
Left and right
Slide the balance control in your mixer all the way to one side to see which is which.
Mar 17, 2014 | Juster Vintage Active 95a Multimedia...
No noise coming from right speaker
Change the volume control potentiometer.
Jan 31, 2014 | Alesis M1 Active 320 USB Speakers
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
Only the left speaker of my alesis m1 active 320 is working properly the one doesnt project sound unless u turn the volume up loud and take out the connection to the left speaker and the speaker doesnt...
have you tried control panel,administrive tools,computer management,device manager,system devices, syatem speaker,right click to update driver,disable,uninstall,scan for hardwarwe changes select properties to troubleshoot
hope this helps
Oct 29, 2010 | Alesis M1Active 320 Computer Speakers
I would like to know if there is a speaker phone option on the Samsung t301g and if so how do you activate it.
yes, the speaker phone is available in samsung t301g
steps to activate the speaker phone
the speaker phone is activates
  • when phone is ringing
  • it shows 'option' on the lower right or lower left of the screen
  • click on the options then there is speaker option
  • click on it & speaker phone is ON
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
sourav
Jan 05, 2010 | Cell Phones
Left output ports for both left and right channels do not work
Hi, first thing to do is to check the power supply look for a larger capacitor & using voltmeter measure both sides from ground to positive & ground to negative. Next check the speaker protection circuit if active. If not active measure the voltage from ground to the speaker output before the relay of speaker protection device. The voltage should be zero or close to zero volt. If more then the power transistor or power IC is toasted.
Aug 10, 2009 | Cambridge Audio Azur 540A Amplifier
How to connect bose 901 speakers to 5.1 setup?
The solution is simple and cheaper than you think.
The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
Your receiver will drive the rest of the speakers.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Sep 09, 2008 | Bose 901 VI Main / Stereo Speaker
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Nov 12, 2007 | Panasonic SB-WA100 Subwoofer
Dell A525 Zylux Multimedia Computer Pc Speaker System W/subwoofer 2.1 Logo
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
