Question about Zanussi WJS1265W Front Load Washer/Dryer
Whats wrong with zanussi tumble dryer tc7103 - Zanussi WJS1265W Front Load Washer/Dryer
SOURCE:
  • 17 Answers
SOURCE: zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Posted on Dec 18, 2008
  • 86 Answers
SOURCE: zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Posted on Feb 09, 2009
michaelcanto
  • 76 Answers
SOURCE: dryer is tumbling but air is cold on TD62 zanussi
is this gas or electric?
Posted on Jul 28, 2009
  • 44 Answers
SOURCE: Our Zanussi condenser dryer, trips the house
I myself would say you have a bad Motor.Something in that motor is not working correctly.
Posted on Nov 20, 2010
mnwarfield10
  • 452 Answers
SOURCE: how do i change drive belt on zanussi tumble dryer
take back cover off ... place new belt bottom first then roll it round tub... WATCH YOUR FINGERS.....if no cover on rear undo two screws on lid (rear).....do as stated above but its harder.07779933829 uk
Posted on Feb 23, 2011
Zanussi TC7114W Tumble Dryer manual
Just click here for the direct download from PDF : TUMBLE DRYER TC 7114 W TC 7114 S
No websites or forwarding, that is just the manual from factory support website.
Vote the solution if this is what you are looking for
Sep 22, 2008 | Zanussi TC7114W Electric Dryer
ZANUSSI TD61 tumble dryer not heating up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 08, 2011 | Zanussi TD4100W Electric Dryer
My zanussi TC7103 s dryer , timer dial is very stiff, and now sometimes sticks when on so that the dryer just keeps going and does not automatically switch off.
i think the timer knob will be binding in the facia panel. you could try working some washing up liquid round the knob to free it up (not oil) the timer may still be damaged but freeing the knob is worth a try a new timer varies from around £37
Jul 25, 2010 | Zanussi TC7114W Electric Dryer
The drum for our Zanussi TC7103 has stopped spinning
sounds like a new drive belt is required. pull the machine out remove the mains supply!!!!
remove the top and look into the back of the machineif you cant see the belt them remove the back of the machine, it's like a small fan felt from a car it's either come off or disintegrated in which case you'll need a new one.
Nov 09, 2009 | Dryers
Zanussi tumble dryer spinning but not heating up
I have same problem and been tol its either the heater or the thermostat inside the front of the drum open circuit hope that helps
Apr 13, 2009 | Asko T701 Electric Dryer
Zanussi TD4212 Tumble Dryer not heating
Could be failure of the overheat sensor
Jan 28, 2018 | Dryers
Zanussi Condenser Tumble Dryer
go to the zanussi web site you should be able to download a manual good luck
Mar 14, 2008 | Zanussi TC7102W Electric Dryer
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Zanussi WJS1265W Front Load Washer/Dryer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
