Question about LG Studioworks 700S 17" CRT Monitor
Blureness of screen
When i turn on the system the screen on lg monitor 17" 700E is blurred,we can be hardly see anything, later after some10 minutes the screen becomes bright and we can see correctly .please tell me what's the problem and solution for it
  • 71 Answers
Either the monitor needs to "warm-up" or be "degaussed"(de-magnetized) upon startup.
Posted on Jun 23, 2009
  • 241 Answers
Not worth repairing, look for a good used one at a garage sale for 5 to 10 dollars.
  • 40 Answers
Sounds like a bad inverter and that is internal. It would have to be fixed by a professional. It is probably cheaper to buy a new monitor.
I have an LG 21" monitor. The screen went blank
Without the model number, it is not possible to research this issue. However... My first suspect would be with the software driver. Some system settings do not like to be oscillated too quickly. (I.E.Going in and out of sleep mode for the computer too quickly, or to and from power save for the monitor too rapidly.) This was a problem especially for older versions of windows. (Vista and prior.) Increase power-save to more than 5-10 mins, and check for driver updates. Being that you were able to get it running without unplugging or turning off the monitor, I do not believe it is a monitor issue. (Outside of the RARE possibility of a hardware or firmware conflict between the monitor and video card/chip set.)
Sep 19, 2011 | LG 22" FLATRON LCD Monitor
My phones died so I charged it and when I try to turn it on it says m blur n the word blur flashes as usual but its been on that same screen for likr ten minutes what do I do?
Hi, well hopefully it will NOT be anything too serious. Now first remove the battery, wait a minute, and replace the battery. Now see if it "Boots up" OK, if NOT, then even though you recharged maybe the battery had a fault, you must in this case obtain a new freshly charged battery, and try that one
try a hard Reset, see below... This will erase all data BUT it may get your phone back.
http://cellphonerepairtutorials.blogspot.com/2010/05/motorola-cliq-xt-mb501-hard-reset.html
http://cellphonerepairtutorials.blogspot.com/2010/05/motorola-cliq-xt-mb501-hard-reset.html .
Aug 25, 2010 | Motorola Mobility CLIQ Cell Phone
My system monitor gets blur within 20 to 30 miniutes ever time when i start system whats the problem ? screen is not clear,it is wide screen sumsung synmaster nnw ,please suggest me whats the problem but...
maybe it is getting too hot? check to make sure that it has air flow around the monitor and that the vent holes are not blocked by curtains, desk, anything that could cause it not to get any cool air to the back of it.
Aug 01, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
My ViewSonic monitor is having an issue with blurring lines. Anything on the left or middle of the screen blurs to the right in a faded color, extremely noticable when I open MS Paint and fill the left...
This is a tipical flyback defect circuit, the lines can 1st appear on top/bottom of screen, then can increase to center. Send monitor to repair center, for check and repair. You can test with a tv test signal.
Dec 11, 2009 | Computers & Internet
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
Monitor has shadows from left to right
Try changing the cable that connects the monitor to the computer, that might improve things slightly, but because you said that it works for the first 15 minutes I'm skeptical that the cable has anything to do with it.
The monitor is near the end of it's life. There's not much that can be done.
Jan 24, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Monitor blacks out after running for about 25 mins
Ok based on just the monitor turning off Lets try this,,
FOR WINDOWS XP
1.) Right click on your desktop
2.) Choose properties
3.) Click on the screen saver tab
4.) Click power
5.) Set The POWER SCHEME to Home/Office Desk
6.) Set the Turn Off monitor to Never
7.) Set the Turn Off hard disk and system Stand By to never
8.) Click apply then ok
9.) Repeat steps 1 - 3
10.) Set the wait time to 30 minutes
11.) Click Ok
12. Shut down and restart your system and wait 30 minutes to see if the monitor will shut off if it doesnt then Your good to go
If it does Then disable the screen saver.. and wait half hour to see what happens
POST BACK HERE AND TELL ME YOUR RESULTS OF THE ABOVE SO WE CAN TRY SOMETHING ELSE
Jan 16, 2008 | Computers & Internet
Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
Dec 25, 2007 | LG Studioworks 775N 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
148 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
