Question about Home Security
No record file found? - Home Security
How to restore audio files from formated Olympus digital recorder
You should stop recording new ones to prevent the old ones from being overwritten. If your digital recorder has a memory card, take it out and insert it to your computer with a card reader. If the device has built-in memory, just connect it to your PC directly. On your computer, you need a video/audio recovery program. Fine one, install and run it. The software will help you scan lost audio files from your recorder, then it'll show you what it's found. Choose the files you want and hit the "Recover" button to start recovery process.
If you're a Mac user, please feel free to try this Mac based video/audio recovery app. http://www.leawo.org/photo-recovery-mac/
May 16, 2016 | Olympus DS-40 Digital Voice Recorder
How to record and how to connect to computer how long does it record
sound , which can be found on windows records for as long as you want I think. Bearing in mind that a file is created that is stored on your hard disk then the size of file that is created must be smaller than this. I voice record a fair amount and sometimes record a couple of hours from the radio here in the UK. If you have a huge hard disk , say 4tb , you should be able to record thousands of hours of audio. One thing...if you do record editing is dificult if you make the files too long.
Good Luck
May 29, 2015 | Audio Players & Recorders
How do I get my computer to recognize Radio Shack FMS 43-127 voice recorder?
HAd the same problem. In the file manager software click "USB" from the top menu bar and then "connect to recorder." It found it after that. Good luck!
Jun 26, 2013 | Radio Shack TRC300 Voice Recorder
Hi! I have an MSF file that was recorded using a Sony digital recorder. Can you tell me what program I will need to download to play this file? Thank you.
I found this info for you. On my recorder, these files are small, and probably do not contain the actual recordings, only data about the recordings. From Sony website: What is the MSGLIST.MSF file? icon_arrow_up_spec.gif Applicable Models: PCM-M10, PCM-D50 Article ID : 1187263 (modified 11/16/2009 11:54:00) Question: About MSGLIST.MSF file.
Answer: MSGLIST.MSF is a file that contains information such as the order of folders, playback order of audio files and recording date and time. If user connects the recorder to the computer, the MSGLIST.MSF files are displayed but do not delete or change these files. If these files are modifed, the saved files may be broken or the recorder may not work correctly.
Hope this helps. ChgoDoc
Nov 15, 2010 | Sony ICD-MS515 Handheld Digital Voice...
I have deleted all my files from my machine, how can i get them back please ?
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
The only thing is send unit to service
Feb 05, 2010 | Olympus WS-311M Digital Voice Recorder
"Invalid Video Found" HDR-CX7 and VRD-MC5 DVD Recorder
The same happend to me. The camera contains informations of videofiles, which are no more present on the camera (were deleted from a computer). You are not able to record in full disk mode, or any other mode, which includes these videos. These missing files can be easily recognised, as the camcorder is not able to play them. Try to get rid of these "files", or ommit them from the recording list.
Dec 27, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
Olympus VN-2100PC exported files
The only way I have found to convert the files is to use Nero or ITunes. Those are the only two methods I've found to read the file. ITunes can both burn them to an audio cd and convert the file to mp3.
Sep 25, 2008 | Olympus VN-2100PC Digital Voice Recorder
Data recovery
If your voice recorder shows on the PC as a removable drive, then you can use PC inspector file recovery Freeware Program : http://www.pcinspector.de/Sites/file_recovery/download.htm?language=1 I use it all the time for Olympus Voice Recorders hope will work for you. Joseph
Feb 18, 2008 | RCA RP5012 Digital Voice Recorder
Home Security Logo
97 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
