Question about Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
My R520-T7 pump hums but will not turn on
When plugged in, it hums but will not come on
  • 739 Answers
Sounds like a jammed or detached impeller, located at the bottom of the pump motor. Repairs are unreliable and replacement is inexpensive ($130 for a comparable pump) recommend replacing the pump.
Posted on Dec 20, 2014
How to factory reset on onkyo 520
To reset theHT-R520 to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "Clear" will appear on the display and theHT-R520 will enter Standby mode.
Jan 13, 2013 | Audio Players & Recorders
My jvc kd-r520 will not turn on. It's as if
make sure the fuse in the fuse box is good then check the relay to the radio is good ( factory relay ) if all thats ok, check the fuse on the backside of the head unit.....
then while the head unit is out check the wires to make sure a mouse did not bite any wires...
Feb 24, 2012 | JVC Car Audio & Video
No fuel to trottle body carberator the car is not getting any fuel from tank
fuel pump is in tank listen to hear it hum when u turn the key on. if its humming then it will be a plugged up filter, if it isnt humming for a few seconds when u turn the key on the test to see if the power is getting to the pump when the key is turned on. it may also be the safety shut down relay if the pump isnt getting any power
Jan 05, 2011 | 1988 Chevrolet Corsica
It turns over but will not start people have looked at it have thought altenator, or battery, or fuel pump...just don;t know
not alternator or battery, maybe fuel pump. You will need to troubleshoot--are you willing?
Please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 07, 2010 | 1997 Chevrolet S-10 Pickup
94 acura turn over but does not start, i pulled a spark plug wire when it was running and it die on me
get into car with windows up close doors so its quiet put key into ignition turn key to on position do not try and start it. when you turn the to on position listen you should hear a hum noise from the fuel tank that will be your fuel pump working the hum will only last about 2 to 5 seconds if you dont hear a hum could mean fuel pumps noy working.
Apr 19, 2010 | 1992 Acura Integra Hatchback
Air Compressor WL611800 not working!!!
does the pump even attempt to run? or does it just hum when you try to turn it on? If it just hums either the pump is locked up or the motor start switch or capacitor is faulty.
Dec 10, 2009 | Campbell Hausfeld Air Tools & Compressors
Motor hums, but propeller will not turn
I HAVE A ZOELLER PUMP AND THE IMPELLER WONT TURN I TAKE A SCREW DRIVER AND TURN IT AND IT WORKS STOP THE PUMP AND IT HUMS CAN THE IMPELLER COME OFF IF IT DOES HOW DO YOU TAKE IT OFF.
May 06, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I think that my fuel pump won't work because i can't start the engine anywaymy car is a dodge sprinter diesel 2007 (v6 , 3.0 l )
place key in ignition. turn to acc ,make sure radio is off listen for small hum it last about 15 to30 sec if you hear hum pump good . no hum check fuse if good more than likey bad pump. check if it has a glow plug
Mar 29, 2009 | 2007 Dodge Sprinter
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
150 people viewed this question
Top Water Electrical Supplies Experts
Lawrence Oravetz
Ottoniel
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
