Question about Weiser Lock POWERBOLT ELEC DEADBOLT
\how to reset a Weiser smart scan dead bolt
I can not set up my Wriser Smart Scan dead bolt.
I gusses the one I brought was a return item. Some body have input an adminstrator, so I can not assign anyone. That make a $200 lock work like a $ 40 dead bolt.
My question is - how to bring it back to work?
  • 2,005 Answers
Http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Posted on Jul 22, 2010
  • papouducafe May 14, 2011
    go to see the following article
    http://www.fixya.com/support/t8006865-no...
    if you want to clear all code you have to program a same new one code on each memory...
    good lock and unlock ;-)
2013 ford f-150 the inst. panel says right rear doir open when it isn't. Lights stay on. How can i fix this problem?
Have body control system checked for DTC'S - diagnostic trouble codes . On newer vehicles like yous ,everything set's a code now a days . Probably a electrical circuit problem or door ajar switch . Looking at data inputs to SJB - smart junction box , fords BCM - body electronics control module , on a scan tool will show what the problem is . The dealer I work at charge's $ 23.00 to hook - up factory scan tool . Or you could take a chance and change the door ajar switch . Would need to take inside door panel off to get at it .
Jan 23, 2017 | 2003 Ford F-150
How to reprogram key fob after jump starting dead battery.
Check the fuses.
If not you will need a sophisticated scan tool to program the keys.
Dec 29, 2014 | Smart Cars & Trucks
Scanner fails to format image
Turn off your scanner. Exit the Smart Touch program.
If XP, navigate to this path: C:\Documents and Settings\[User Name]\Local Settings\Application Data\Smart Touch\[Scanner Model]
Windows 7 or 8: C:\Users\[User Name]\AppData\Local\Smart Touch\[Scanner Model]
Delete the "Sys" folder. Turn on the scanner. Re-open Smart Touch. You will see the Sys folder repopulate in the root folder.
Mar 27, 2014 | Kodak i1220 Pass-Through Scanner
Sorry my scaner not working but printer will be working please tell me whats wrong
  1. The firewall must allow the following traffic.
    • TCP on ports 9400 and 9401
    • UDP on port 6000
  2. Make sure Scan Manager is configured for the correct IP address of the printer. If Scan Manager will not launch from SmartPanel and it does not show up in Control Panel, check <WindowsDirectory>\twain_32\Samsung. Without Scan Manager installed the printer will not be able to scan to PC.
To use Scan Manager you will need to have installed and configured the following items:
  • Installed the Print Driver, including the Smart Panel application
  • Installed the Scan Driver, including the Scan Manager application
  • Have an active connection between the Printer and PC
Important: If you don't have these items in place, stop now and perform the installation.
To scan to the PC using Scan Manager, follow these steps:
  1. Right click Smart Panel in the task bar, and then select Scan Manager. (Scan Manager Admin dialog appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=bdbe6a5u2kt1@namo.co.kr&sep=%7c
  1. Select the Printer you want to use, and then click Quick Scan. (Quick Scan dialog appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=pdq8czuzqk7f@namo.co.kr&sep=%7c
  1. Once the Quick Scan dialog appears set the following parameters:
    • Save Location - To change the default location click the Folder Icon to Browse for Folder.
    • File Name - The default file name is the date and time the scan is performed. To change the File Name, select the File Name field.
    • File Format - The file type selected will be the default file type for each consecutive scan. Select from the following formats. (TIFF, PDF, BMP, and JPG)
    namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=q0imt82cnhs9@namo.co.kr&sep=%7c
  1. After entering the previous information, click OK. (Scan Manager appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=1oy6sc87xa6m@namo.co.kr&sep=%7c
  1. Click Scan to scan the document to the PC.
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=45q4kejs8a31@namo.co.kr&sep=%7c
For additional information about Scan Managers' features and settings, click the question mark icon (?) at the top of the application window.
Dec 23, 2010 | Samsung SCX 4521F All-In-One Laser Printer
I need to scan A document using an epson RX425 printer how do I do it #
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
Jun 10, 2010 | Epson Stylus RX425 Multifunction...
I have an epson stylus photo rx500, but have lost the installation disc and have no smart panel function so cannot scan or copy and espon are useless and say it was a bundle and newsoft supplied the...
You do not actually need Smart panel to use the scanner. Epson scan will allow you to scan and save to the PC etc. To install the printer and scanner download and install Epson Scan and Driver from the following page. http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7MDXMcEkJfQFa89pC7QCDCv&tc=6#7
Jan 17, 2010 | Epson Stylus Photo RX500 Printer
Need instlation insructions
Here's the installation and operation/programming instructions for your lock set.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Weiser and Kwik set both sold and marketed the same lock under their own brand names, as Weiser was the manufacturer, these instructions apply for your lock set.
Hope you find this Very Helpful and best regards!
Jul 30, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Still looking for Smart-Scan software
You can program the scan button by going to "Control Panel" and "Scanner's and Camera's.
Right Click the scanner and go to "Properties"
Select the "Events" tab
It should allow you to program your one touch button from here. I just wanna verify that you do have the CX3200 and not a Stylus Scan 2500?
Aug 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Automatic RETURN/ENTER ...
I set scanner to defaults and had to Scan Bar Code labeled <DATA><SUFFIX 1> on page 4-50 of LS 2106 Product Reference Guide to set return after scan.
http://www.intermeccorp.com/pdf/2106setup.pdf
May 13, 2008 | Symbol Hotshot LS2106 Handheld
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
1,884 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
