Question about Plumbing
Slow bath tub drain - Plumbing
  • 374 Answers
SOURCE: Bath tub drain
You need to replace the overflow cover with the lever on it.You can replace the entire piece or just the faceplate.There is a spring on most of these that holds the lever in place when thrown and that is the piece that is broken causing your issue. Thanks for using Fix Ya.
Posted on Mar 11, 2009
venexcsd
  • 1185 Answers
SOURCE: can no longer drain tub unless I use a piece of plastic under the plug and use this to pull the plug out after the bath
At the base of the plug there is normally a stud with a thread on it to allow you to raise and lower the plug so that it seals or empties.
If that is not how your oulet is made then there is a lever behind the or to the side of the outlet underneath the sink, that also is adjustable on most sinks.
Sometimes it is via a spring clip which rusts and loses its grip
Posted on Jun 02, 2009
  • 41 Answers
SOURCE: Backimg to bath mat disintegrated in washer.
have you tried cleaning inside the rubber gromit attatched to the underneath of the drum? if its not that you might wanna try cleaning out the pump itself. may have jammed hope that helps
Posted on Mar 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: This might be a plumbing problem but it only
Check your main vent line for obstructions (animals, nests, leaves, etc.) and then have your drains inspected. There is likely a "log-jam" (pun intended) in the sewer drain line - as it is not allowing the water to drain as fast as the washer pumps it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 26, 2010
  • 293 Answers
SOURCE: my tub is slow to drain. How do I take apart my
Hi and thank you for using fixya:
Taking apart can be expensive and hard. Here is how to do it.
1-Remove your tub lining
2-remove tub
3-you will have access to the pipe
I would suggest buying a pipe cleaner they work really good
good luck
Posted on May 02, 2010
A slow daring dathtub
put a part fill in the tub( about 1" deep) with the plug attached to a bit of wire
pour about 1/4 cup of draino ( sodium hypochlorite ) into the water and stir with a broom handle or suitable stirrer pul the plug out and the mixture will dissolve any hair, soap and grease that is blocking the system
NOTE
SODIUM HYPOCHLORITE IS CAUSTIC ( BURNS THE SKIN AND EYES ) SO USE RUBBER GLOVES AND SAFETY EYE WARE AND USE EXTREME CARE
FLUSH THE BATH WELL WHEN DRAINED
Feb 22, 2016 | American Bath Home
How to remove bath tub pop-up stoppers
Put the lever in the open position so that you can grab the stopper. After you get a grip on it, put the lever in the closed position and the drain plug and rocker assembly will pull out in a horizontal direction.
Sep 25, 2014 | American Standard 1583.470.020 Universal...
Why does my geberit bath waste plug leak water?
It's adjustable. Remove the drain lever from the side of the tub. Now you can withdraw the whole drain assembly. Clean it well, then reinsert it to see if that fixed the problem. If not, try adjusting it longer.
Dec 24, 2013 | Geberit Bath Waste and Overflow Tub Drain...
I can not close my bath tub drain. the plunger is all internal and wont come out either. I tried a coat hanger to push it down. no go.
on most tubs the stopper is made to come out! does the stopper have 2 screws at the stopper lever. if it does just remove these screws and pull the stopper out slowly. when putting in a new one. have the same length as the old one, then slide it back in the drain fairly slow until it goes all the way in. replace screws and try it! good-day!
Aug 05, 2011 | Kohler Bath Drain KOH-K-7104
This might be a plumbing problem but it only happens when I do a load of washing. When the water drains it goes into a pipe in the wall and then my bath tub fills up and the bath drains .when the water is...
your drain line is plugged up or broken somewhere in the yard,,,try running a pipe snake and see what you come out with,,,come out with mud-you have a broken pipe drain from a tree root!
May 14, 2010 | Washing Machines
This might be a plumbing problem but it only happens when I do a load of washing. When the water drains it goes into a pipe in the wall and then my bath tub fills up, and the bath drains .When the water...
Mar 26, 2010 | Washing Machines
Slow drain new whirlpool
yes, it could be.also may be build up of waste,(hair,etc) is the rest of bath room performing ok,has this problem just appeared ?just something's to look into
Feb 17, 2010 | Home
Water is leaking from bath tub drain
the most common reason for a drain to leak is that the plumbers putty around the drain where it meets the sink or tub has dried out and has a crack or void in it. Unscrew the drain from inside of the tub and check the plumbers putty. There is an inexpensive drain wrench sold at hardware stores, lowes and home depot that makes this an easy fix.
Apr 26, 2009 | Kohler Model 7202: Drain For PuristĀ® Baths...
Plumbing Logo
78 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
