Question about Nixon The Unit Watch
Light does not work button just beeps - Nixon The Unit Watch
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Oct 18, 2013 | Armitron All Sport Digital watch
The buttons are not responding for my puma touch sensor 30 lap
You have to leave the light button pressed until you click there and beep and buttons work
Apr 19, 2012 | Puma Active Collection Fluctuation...
Automatic light function.
There is a button below the face of the watch that has the atomic watch symbol on it. Hold this button down until you hear a beep and it will turn that function off. To turn it back on, press & hold the same button until you hear a beep.
Oct 15, 2009 | Casio G-Shock GW500A-1V Wrist Watch
I don't know how to turn off the automatic light feature on my watch
There is a button with an atomic time symbol below the face of the watch. Press and hold this button until you hear a beep and the light will go off. To turn it back on again, just press and hold that same button until you hear a beep and it will come back in automatically when you tilt your watch.
Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
Jun 18, 2009 | Adidas Candy Digital watch
Need instructions or a manual on how to stop beep mode on watch
To turn hourly beep on/off: Hold the RESET button (lower right) and press the MODE button (lower left). When the days of the week light up, the hourly beep is on; when the days of the week are off, the hourly beep is off.
To turn the alarm on/off: Hold the RESET button and press ST/STP (upper right). Alarm light will go on/off.
Mar 26, 2009 | Watches
I Lost My Small Book on How to set my new Fossil watch Model JR9455-300703
Finally i got it while playing around with my fossil JR9455. . .
Here's the step by step method in setting the time:
1. press and hold light button and press start/split button
(light and start/split are both pressed by this time)
2. you should hear a beep
3. You should notice that the display changed
4. press mode to choose which setting you want to change
5. to change the values, just press start/split button to move up and reset/stop button to move down
6. to finish the setting just press light button again.
This method worked with my watch. I hope this helps. . .
-chickozai-
Jul 05, 2008 | Watches
I have a Timex Ironman 53151 watch but there is no sound. The light and everything else works except the sound. What is wrong with it?
got a new battery in ironman and the beep will not sound when i press the start and end button on while in stopwatch mode
Apr 19, 2008 | Timex Ironman 53151 Wrist Watch
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Nixon The Unit Watch Logo
35 people viewed this question
Top Nixon Watches Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nixon Watch Expert? Answer questions, earn points and help others
