Question about Kenmore 64802 Top Freezer Refrigerator
Water driping on top shelfe from freezer,
At the back of the freezer appers to be a drain, but water is frozen in it, so water driping to shelves. what is the temperature of freezer supposed to be.
    President:
  • 744 Answers
The drain most likely was blocked by food debris and the water from defrost cycle had no where to go...unplug refridge...chip some of the ice along the bottom carefully or use heat gun to melt ice...when the tube becomes exposed put some hot water in the drip pan..this should help the ice melt in the drain tube....use a straw or curtain wire to clear blockage...you should see the water suddenly drain down tube...put everything back together...this is not a temp issue but more a blockage issue.
Posted on Jun 23, 2009
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Water is leaking onto top shelves of unit
Hello, Thank You for using FixYa. I will be helping you today. Your drain line is most likley frozen. You need to remove the shelfs from the freezer and the bottom slide out panel. Remove the screws holding down the plastic bottom piece in the freezer then remove the back panel in the freezer. Remove any ice buildup you can. The drain is in the middle under the evaporator. DONT TOUCH the evaporator. Use boiling water and pour it in the back untill the drain runs free.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | KitchenAid KTRS19KK Top Freezer...
Water inside on shelves can not determine where it is coming from checked back of refrigerator can not see any leaks inside or outside. cleaned up water cleaned under fins etc one day later more water...
A temporary solution is to remove all frozen food, ice tray,shelf and bottom plate. you will see the water drain trench and a drain hole in the back center of the freezer. Unplug the drain, free it from ice or debris and flush with hot water. I have the same problem with my frig. This is not a permeant fix, but it will stop water from dripping through the vent ports The defroster may be defective or the air flow is too restricted. Good luck.
Jan 02, 2011 | Kenmore 64802 Top Freezer Refrigerator
I have a Kenmore Elite top freezer refrigator. Water is driping or somehow forming on the top shelves [under the top freezer] and a thin layer of ice will appear and the water contuniues to form. then over...
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 02, 2009 | Kenmore Refrigerators
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Water is leaking into my refrige
You have a drain in the back of the freezer and a drain on the back of the refrigerator. Check them both to see if the freezer drain is frozen or the refrigerator drain is clogged. Thaw out with a hair dryer and hot water if it is the freezer drain.
Oct 25, 2008 | Kenmore 22422 Top Load Washer
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Upright freezer not cooling
The model number would help but it sounds like a sealed system leak or restriction. If thats the case I would not suggest trying this yourself. The water should freeze overnight and the frost should keep going to all the shelfs that have coils in them.
Apr 16, 2008 | Freezers
Kenmore 64802 Top Freezer Refrigerator Logo
170 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
