Question about Epson Stylus Nx420 All-in-one Color Inkjet Printer
PAPER JAM W-02
IT INDICATES A PAPER JAM BUT THERE IS NO PAPER IN IT
2 Suggested Answers
Inzanio09
  • 38 Answers
SOURCE: Indicates paper jam,I followed troubleshooting for
From another site...
"This can be caused by anything obstructing the carriage area, like a
paper clip or small scrap of paper. The other reason this may occur is
if the lubrication for the head carriage becomes sticky or dried out.
Usually to correct this, check the rails or guides that the head
carriage rides along, and clean them with a lintfree cloth. Then
replace the removed lubricant with an appropriate type of lubricant
(3in1 or sewing machine lightweight machine oil for oiled contact
points, a lightweight lithium grease for greased areas."
I also know that any paper jam, or bum can dismantle springs and bits and pieces inside, as it's a common error with a lot of printers.
The only 2 things I can suggest are too..
Search Online and find the Manual for your printer, and see if it's in the FAQ or support for common issues.
OR.. what I usually do, like yesturday when I worked on a client's printer with the same error, is to dismantle the back, take off the cover, and depending on the model, there are usually springs or an arm that works with the feeding of the paper and/or direction of it. If they are not in the correct place/look bent, etc. Play around with it.
Otherwise there isn't much else you can do. Printers are not worth repairing, and the manufactures do not count such issues under warranties - bastards. ( >=( ) so other than that, buy a new cheapish one.
Hopefully I have been of some assistance!
Posted on Jul 01, 2009
E4 02 error code
Paper Jam Causes 1. Paper Jam in Fuser Unit. 2. Paper Exit Sensor clear and close the front cover
Jan 10, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
Epson sx438w e-02
did you check paper feed driver unit sensor in paper fixing fil or board
Feb 19, 2013 | Epson Stylus Sx438w
Have an Imagerunner 5180 giving err code E000007-0102 - Tried to clear it while in the service mode and it continues to give shutdown sceen - cant find anything physically wrong with the copier - Anyone...
Item Description Remarks AAA Indicates the numbers of jams
(larger the number, the more past the jam). 1 to 50 (50 max.) BBBB Indicates the date of occurrence. Month, day (2 digits each) CCCC Indicates the hour of occurrence. 24-hr notation DDDD Indicates the return of recovery. 24-hr notation E Indicates the location of occurrence. 0: copying machine
1: feeder
2: finisher
EFff Jam code. FF: jam type (T04-201-01)
ff: jam sensor (T04-201-02)
(For the feeder, T04-201-04.)
G Indicates the source of paper. (T04-201-03) HHHHHH IIIII Indicates paper size.
Mar 14, 2010 | Office Equipment & Supplies
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
I have an error that indicates paper jam, open-- imagistics 2500
Check the paper trays sensor,and describe detailated the your problem and please tell me the fax machine models for more help and information.
Sep 17, 2009 | Office Equipment & Supplies
HP 4L printer indicates no paper when the tray has
When you removed the paper jam, was the paper torn? If so, did you ensure that you found all the pieces. (Put the piece of paper back together like a puzzle to verify). There could be a piece of paper stuck in the printer that is causing the paper sensor to fail.
The other possibility is that when you removed the paper jam, something became dislodged in the printer. Forcefully removing paper from the printer can cause this.
Jul 16, 2009 | HP LaserJet 4L Printer
False paper jam on HP Office Jet V40
hp officejet v40 indicates a paper jam and it is cleared nothing
Apr 04, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Blinking lights
This generally indicates a paper jam. I had this happen just yesterday, and SWORE there was no jam. And of course my wife looks at it for 2 minutes and finds the paper jam. So be sure to give a serious lookover 2 or 3 times, and get a fresh pair of eyes on it if you still cant locate it.
Jul 29, 2008 | Brother HL 1440 Laser Printer
Epson Stylus Nx420 All-in-one Color Inkjet Printer Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
