Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Canon sd750 when i try to take a picture a black screen appears does not allow me to see the picture.
  • Canon Master
  • 4,738 Answers
Did you accidentally press the DISP button on the back of your camera? Press it once to see if that corrects the problem.
Posted on Jun 23, 2009
  • CameraR
    CameraR Jun 24, 2009
    I'll take it that didn't work. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
    To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
    http://camerarepair.blogspot.com/2009/05...
I was taking a pictures and all of a sudden the screen went black and now all the pictures i take come out black
The mirror inside your camera lenses appear damaged or displaced which is responsible for properly reflecting light (otherwise comes out black or too exposed). Send it back for repair.
Jun 29, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
When i turn on my sd750, the back screen appears dark (cannot see what the camera is point at and when i take the picture, it is black ... in the past i was able to retify but putting on and off a few...
There usually is a button on the camera which will affect the LCD operation. On these Canons usually it is marked with a small monitor icon or it has "Disp" next to the button. This is on the surface of the camera and not in the menu. It will also be in the menu, but since you cannot see the lcd display, then I assume you have to try to use the buttons on the camera.
Dec 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My screen went black and I can't take photos. all other funtions work.
try to take a picture even when you do not see anything on its screen. If the picture taken shows up afterwards, you will just need to adjust the brightness for the LCD.
Oct 23, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Blank screen
Try this...if you can still get into the setup menu, scroll to "reset" and follow the on-screen instructions. If not, remove the memory card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on. Did that help?
Sep 28, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black Screen on Canon PowerShot SD750
Probably bad CCD. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Sep 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black screen
screen belt is cut off. send to us
Jun 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Turn on camera but the lcd sceen is black
I tried all the solutions offered on the net and none worked except one. It simply said "hit the camera with the palm of your hand" (when it is on) and the screen will return. I thought, well I have nothing to lose and so I hit it on the side and sure enough the LCD is again working !!! Contacted Canon prior to this and they had no idea but suggested I send it in to be repaired at a cose of $163.50 Australian. Pleasant staff they have, but no help in solving what looks like a common problem of Canon cameras. I will have second thoughts purchasing Canon from here on in.
Mar 23, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
320 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
