Question about Stihl FS 85 Weed Eater
Weedeater starts and runs, when you give it gas it it smothers and dies
3 Suggested Answers
RALilja
  • 398 Answers
SOURCE: weed eater runs but wont take fuel acts like running out of gas
Hello David,
You most likely have 1 or 2 problems causing this problem, both which have to do with the carburetor reservoir bowl.
1. The bowl is contaminated with dirt in with the gas causing the port to be clogged and won't allow gas to be siphoned into the carb /engine.
2. The rubber gasket on the top of the bowl is cracked due to the alcohol in the gas and needs to be replaced!
Rich Lilja
Posted on Sep 04, 2016
  • 12962 Answers
SOURCE: my stihl weed smother outwhen I giveit gas
Carb jets need adjustment.
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
2002 dodge caravan sport....starts fine but idles rough....try to give it gas and it smothers out
Any check engine lights on? When you are giving it gas and it dies, that is either because there is not enough airflow to support the extra gas, or there is not enough gas to support the extra air. So check the filters for air intake and the fuel pump pressure. The pump is in the gas tank so it is a real pain to replace. It could be the injectors too.
Sep 20, 2013 | 2002 Dodge Caravan
Out the box.Cranks and runs on cold.when you give it full throttle and knock it off fast idel try to let it idel it die's.After u use it a few min. it die's and want start back till it cools.
This is a common problem out of the box for weedeater products. This simply needs a carb adjustment which is not something the consumer can do (requires a special tool), You will need to take this to a weedeater dealer near you to get it done, it's covered under the warranty.
Jul 21, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a weedeater and that is thebrand name as well,the weedeater only starts up while in the full choke mode,when I take off the choke and give it some gas it dies everytime?
Likely you have gum buildup or a particle in the jets of the carb. Usually, you have to disassemble and clean, BUT you can try the old trick: pull the air cleaner, run the unit as fast as it can go, using choke or whatever makes it go, and then place palm over intake. Sometimes this will **** the obstruction out.
Sep 26, 2010 | Garden
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
May 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Wont run when you pick it up or give it gas
Make sure your fuel line, with filter has slack to move around in fuel tank.
May 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Stihl FS 85 Weed Eater Logo
44 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
