Question about Northern Wire Kleen Flo Intake Screen
Order kleen flo replacement bag
Lake pump screen has a hole
My robo kleen is moving but wont suck up the leaves and dirt
Possible blockage in the base where the leaves enter into the bag.
Jul 20, 2014 | Smartpool Robo Kleen
Robo kleen pool vaccum- not sucking- wheels move - prop on top turns very slow
if you hear a buzzing sound
there is water in the motor
if it drives ok, the power supply should be ok
try draining the water out of the small plate and plug shown
when you take out the filter bag
it will probably happen again
but a motor can be expensive to replace
Jul 31, 2012 | Smartpool Robo Kleen
I have a Robo Kleen robotic pool cleaner, it still moves around but is no longer picking anything up. The bag is clean. Can I purchase a pump for it?
You should be able to purchase pumps for these automatic pool cleaners from a pool supply company, but I would take it to a professional first. It could be something that is easily fixed without purchasing an expensive part.
Aug 24, 2010 | Smartpool Dolphin Robo - Kleen Above...
Need to order new bag,where, how.
The SmartPool website has an option for entering your zip code and finding a dealer/repair service in your area. They will carry replacement parts for this pool cleaner.
http://www.smartpool.com/website/#
Aug 01, 2010 | Smartpool Dolphin Robo - Kleen Above...
Replace front brake pads - any special instructions?
Nothing hard about it , just make sure to lube the sliders with a quality product such as eze slide by kleen flo.. I also use disk brake quiet on the backs of the pads when installing.
Jul 29, 2010 | 2005 Dodge Durango
I have a robo-kleen pool cleaner which stops
If debris is entering the bag, it may be as simple as that. The bag is clogged. We typically recommend hand cleaning a pool before using an auto cleaner specifically for that problem. You might have to remove and clean the bag 50-75 times. Much easier to hand vac first. If no debris is getting into the bag before it stops, it could be a problem with the motor. we have seen them "short cycle" and require replacement. Rob
Jul 14, 2009 | Pool & Spa
SEal replacement on Flo-Master 1 hp 2 speed pump? Tough to remove. Any tips on removal?
Pump seal is in two pieces. The piece with the spring should be easy to remove. To remove the piece that is inside the motor side of the pump housing, place the housing with the side that should be facing the motor downdwards on a flat surface. The hole in the housing is larger than the seal, so use a screwdriver and, placing first on one side of the seal and then the other, strive the handle of the screwdriver sharply and the seal should pop out the bottom. The seal is rubber, with a ceramic insert, so if you don't tap the screwdriver too sharply the insert won't be damaged. In any case, it's a good idea to replace the entire seal if you have had to open the pump and remove the impeller
May 23, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Robo kleen stopped working, motor starts but it does not move
Hello, I think I had the same problem with mine : the filterpump worked, but robot didn't move. I opened it up and the problem seemed to be that the pin which locks up the gear wheel to the axle of the front wheels had broken into three pieces. We inserted a new pin (nail, screw etc) and the Robo kleen works just fine again. Maybe you should check this is also the problemwith yours. Good luck !
Apr 09, 2009 | Smartpool Dolphin Robo - Kleen Above...
Pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Dec 04, 2008 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Northern Wire Kleen Flo Intake Screen Logo
210 people viewed this question
Top Northern Wire Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Northern Wire Health and Beauty Expert? Answer questions, earn points and help others
