Question about Tivo Televison & Video
After storms and loss of power for a couple of short periods, Tivo will not display on screen. The only indicator on the machine is the green light. Does this indicate a non fixable problem?
MikeNJ1964
  • 398 Answers
SOURCE: Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Posted on Jun 28, 2007
SOURCE: power saver
dead
Posted on Jan 03, 2008
SOURCE: Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Posted on Jun 06, 2009
SOURCE: TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Posted on Jul 31, 2009
  • 9 Answers
SOURCE: HP 1740 NO Display
probably a transistor problem, replace them /2. C5707
Posted on Dec 08, 2009
Tv signal blacks out periodically
You might want to consider if this is a Cable box/TIVO issue before blaming the receiver. After all, if you can pause and rewind live TV you're probably watching all content through the hard drive.
Or suspect a marginal connection from the TIVO to the receiver if that is what you have. Does the receiver give any indication of digital signal loss when you lose audio?
I skip some of this exposure by running the video staright to the TV (the more interconnects, the more opportunities for problems).
Jul 01, 2010 | Audio Players & Recorders
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
Tivo series 2 TCD540080
The green light on the left indicates that the Tivo *is* on and running.
Have you changed your TV to the correct input that the Tivo is connected to?
Jun 06, 2008 | Tivo Series2 TCD649180 DTV Receiver /...
Toshiba 56PW8 rear projection - lost sound and picture after powercut
The convergence amps in those units consist of two Sanyo STK392-110 Ic's that get hot enough to fry eggs.. If your storm flexed voltages enough it could have easily shorted the amps and/or take either of two pico fuses in the 24v supply line to the amps... If you're not too tech savy this is one for a reliable shop and not and expensive fix. Two Sanyo Ics and a couple pico fuses should be more than $50.00 dollars and a couple hours of labor to put them in... While they're at it have them check the caps in the hyper module and for any ring cracks in the deflection circuit...
Bill
Jan 09, 2008 | Toshiba 50H72 50" Rear Projection...
Xerox 8200 will not boot
If it takes a long time to cycle, then shuts down. I suspect the drum heaters are defective.
Best way to find that out is, turn off yout room lights, then turn the machine on.
There is a fan exaust on the right side of the printer where there are sloted openings.
When you turn the machine, look in that fan slot and see if you see lights inside the printer. There should be a candesent type of glow you see about 20 seconds to a minute after you turn on the machine. Leave it on for a couple of minutes, but if you see no lights the heater or heaters are bad. They are standard 120 volt 150 watt halogen lamps. Tricky to change. But it can be done.
Dec 28, 2007 | Xerox 8200/DP Thermal Printer
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
Sorry to inform you my freind, but the main board has to be replaced in this beast. Could get expensive. there are no schematics and or componets listed to repair this module. Its a board level repair only. Try going to ptscorp.com, find their phone number, and see if they repair these boards. if not you will need to contact the manufacturer for replacement boards. good Luck Please do not forget to rate this thread.,
Dec 15, 2006 | Fujitsu Plasmavision PDS-4209 42 in....
Televison & Video Logo
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
