Question about Frigidaire FAS257S2A WallWindow Air Conditioner
Frigidaire FAS257S2A compressor does not run
Compressor does not turn on
When pluggged in, all lights behind the buttons on control touch pad panel light up, then go out. When the 'on' button is pushed, nothing happens. Can you tell me what the problem is? Thanx
First thing to try is turning off the power to the machine for a minute and then turn it back on, if that does not fix it then electronics have a brain problem. I have noticed that appliances with electronic panel controls are having many problems, my washing machine electronic control panel is bonkers but never had problems with the old mechanical controls. In order to fix mine I would have to order the whole panel as you cannot replace parts, I'm sure you unit is the same.
Mar 12, 2018 | Frigidaire Heating & Cooling
Frigidaire airconditioner compressor keeps running after turning the unit off
Thanks for the post, friend!
I understand that the compressor continues to run after your Frigidaire air conditioner has turned off. From that information it sounds like there could be a possible issue within your control panel or relay. I would recommend a reset on the appliance, to perform a reset unplug the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in. If you continue to have an issue with your compressor I would seek assistance from a professional. Hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire 18,500 BTU Window-Mounted...
How do you clean the coils?
Good Morning Friend,
I understand you want o know how to remove the coils to clean them on your Frigidaire air conditioner, model# FAS257S2A. You will not be removing the coils. If you will please start by cleaning the filter like so:
• Tilt the panel out by grasping the panel from both sides, just below the controls and the air directional louvers, and gently pull to release. Pivot the panel on its hinge's and remove the filter.
• Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
• Or, instead of washing you may vacuum the filter clean.
While you are cleaning the filter, the coils will be located behind the filter area, you can clean them with a vacuum extension. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FAS257S2A WallWindow Air...
Will not get cold
Hi Ebony! Are you having issues with the unit turning on at all and staying on? Or do you not hear the unit turning on and running? If you hear no noise, to show the unit is running (compressor turning on), you would need to contact a professional at your earliest convenience. The compressor and sealed system are not turning on. If you hear the compressor running, but the unit is not cooling you have a coolant/sealed system concern. Please contact Frigidaire and a professional to repair the unit.
Sep 04, 2013 | Frigidaire Freezer GLRT183TD
I'm trying to locate the filter # so I can replace the filter in this air conditioner. Also, I need step by step instructions on how to replace the filter.
Unless the filter is totally destroyed , it is a washable reusable filter. Or if it's not extremely dirty, you can vacuum it to clean it.
If it's extremely dirty was it in warm water and mild dish washing liquid. Rinse thoroughly, shake any access water off and allow to completely dry, before replacing it. Never operate the unit without the air filter in place.
Always turn the unit OFF & Unplug it, before removing the filter.
If the filter is completely destroyed, go to the following link to locate a Frigidaire Parts Distributor near you. http://www.frigidaire.com/partsdistributorlocator
I hope the above information helped you and thanks for choosing FixYa.
Aug 10, 2011 | Frigidaire FAS257S2A WallWindow Air...
The light says filter reset. what do i do?
Wash the filter then you can reset the filter alert.
May 25, 2011 | Frigidaire FAS257S2A WallWindow Air...
Motor bearings are making noise. Can I get bearings or do I have to replace the whole unit?
From all the manuals that I have checked you are going to have to replace the motor as this is a sealed bearing and is not replaceable.Thank you.
Apr 29, 2011 | Frigidaire FAS257S2A WallWindow Air...
Hello, my air conditioner trips the breaker when compressor starts. thanks
Check compressor for electrical Short
You might need serviceman for this.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Frigidaire FAS257S2A WallWindow Air...
Frigidaire FAS257S2A WallWindow Air Conditioner Logo
80 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
