Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Where is the seal on stackable washer
Took the inner tub out, still has out catch tub, but where is the seal, my washer is leaking at the base underneathe
5 Suggested Answers
SOURCE: Seal separated from tub (not torn)
on the outside it just goes back onto the groove and pushed back on - - go all the way around to make sure it is on all over
Hopefully it is not the inner part because that is held by a very strong spring it took 4 hands 3 wooden spoons and a few fingers to get it back on. .
Posted on Apr 29, 2008
chris0fer
  • 5 Answers
SOURCE: My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Posted on Jun 19, 2008
SOURCE: oil leaking from underneath agitator
looks like transmission is leaking, try changing the seal
Posted on Jan 13, 2009
  • 70 Answers
SOURCE: AFTER REMOVING THE INNER TUB NUT HOW DO YOU REMOVE
Are you talking about the wash basket?
Posted on Jul 10, 2009
Frigidaire gallery series Model GLGH42FS1 stackable washer leaking
see this causes and fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Oct 11, 2012 | Frigidaire Washing Machines
Kenmore 417 97962705 Leaking below tub from transmission gasket
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Sep 28, 2012 | Kenmore 98702 Stacked Washer/Dryer
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Rubber Seal leaks
You have to replace the whole door seal.It can be done through the port hole,difficult but achievable or you can strip the front of the appliance off and do the inner part easier.
Unplug the appliance.
Open the door and take the seal retaining ring out of the door seal.
Peel the door seal off the front panel and fold it inside.
Take the seal retaining ring/spring out of the tub side of the seal.
Pull the seal off and take it out of the appliance.
Fit the new seal to the tub,look at the seal and tub for matching arrow marks to help align it.
Fit the retaining ring/spring into the groove in the seal and over the lip of the tub.
Fit the seal to the front panel and then fit the retaining ring into the seal.
Restore the power to the appliance and leak test it.
If you find you can't get the seal on.
Take the top off the appliance.
Take the dispenser out.
Take out the screws revealed.
Take out the screws holding the door lock.
Take off the plastic cover below the door and remove the screws revealed.
Take the front panel off.
If the panel won't come down and off there will be a hidden screw that requires the facia panel to be removed.It's snap together plastic,just release the catches and carefully remove the facia.
Take the screw out, take the panel off.
Fit the inner part of the seal to the tub.
Reassemble the front of the appliance.
Fit the seal to the front.
Leak test the appliance.
Apr 06, 2010 | EuroTech EWF150 Front Load Washer
Leaking from the bottom of the washer.
it sounds as if the main tub ring is bad you need to pull your agitator out and check the two blots that hold the tub to the shaft and make sure they have not become loose or broken causing the inner tub to drop on the shaft and tear the tub seal.
Feb 23, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Inner tub broke away from outer tub casing
Time for the dump. Probably need a new tub lock nut but there may be more damage to the transmission or tub seal which will leak water and it may not be worth the $100 service call for a Tech to tell you you need a new washer. Good time to buy appliances right now, try to get free installation!
Jul 21, 2009 | Frigidaire FWS1339A Top Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer leaking from bottom of tub
If you have the tub out the seal can be removed by taking the brass ring off the shaft, its on top of the seal, then grab the seal with a pliers or pry it out with a screwdriver etc. The new seal will cost about $40-$50. when you put the new seal in put the rubber part on first, careful to not tear it on the slot cut in the shaft to mount the basket. Next put the old brass ring on top of the new one, use this to push the new ring on, this will help get it over the notch for mounting the basket. When the new ring is ontop of the seal remove the old ring, reassemble, check for leaks.
Jun 08, 2008 | Frigidaire FWS833A Top Load Washer
Apr 29, 2008 | GE WSXH208A Front Load Washer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
15 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
