Question about Supra 001004 Push Button Lock Box Key Safe
I have moved into a house with a key safe, but do not know the code to unlock any ideas?
How to reset number code on my secursafe. I bought never set it up I have key but dont know how to set up safe with pass code
Open the safe with your key (key slot behind the blanking plate btween the safe knob and the keypad).
on the back of the door is a plastic housing put your hand on the side of the housing near to the hinges, you will feel a small push button.
Press it once the unit will beep and the far right led will illuminate.
key in your new code (8 digits) then press either A or B.
Job Done!
Feb 14, 2017 | Home Security
Well when I got this safe I had it for not to long and my safe was stored at a friend's house while I was in between moves well my purse got stolen that had the combination in my wallet and now my safe has...
It is good that you have the keys. Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Mar 25, 2015 | Home Security
I'm at a motel. The safe says E-bar even after I put my code in
E-bar means the door lock is jammed, use your clenched fist and after inputting the code to unlock hit the door of the safe all around the key pad as hard as you can, you will hear the rods moving and unlocking the door. Hope this helps. I know it works as I have done this in motels I've stayed in!
Feb 08, 2015 | motel6.com Computers & Internet
How to open sentry safe s0130 after being moved
Spray the key hole with graphite. Should loosen up whatever is stuck.
Jul 20, 2014 | Sentry Fireproof Safe
Low batteries in my safemark safe- how do i open?
e-bar is not a battery problem, it means the door lock is jammed, either use a rubber malet or your balled up fist and after inputting the code to unlock hit the door of the safe all around the key pad as hard a you can, your will hear the rods moving and unlocking the door. Hope this helps. I know it works I do this at the hotel I work in.
Jun 08, 2012 | Safe International Home Security
LOST CODE ON SUPRA C LOCKBOX
I have just moved into a house that has a supra combination code key safe mounted on a wall outside the back door , it was put there by the first owner who died ,the second owner never used it and don't know the code,I just thought it would be handy to use as we are going away in June to France and its away of leaving a key in case the alarm goes off while away so a neighbour could deactivate it or the police so they don't have to brake down the door or if I get locked out I could have that key for emergencies so is there a way I could find the code for the safe please?
Aug 31, 2011 | Supra 001004 Push Button Lock Box Key Safe
Moved house can't find keys and have forgotten code
Take a small hand held electric grinder 3in. disc...buy a 3in.metal cutting wheel..(cheap)
cut a square hole in top of box.....you are in....remove items recycle metal box.....It is best to buy one that takes keys also.
Feb 27, 2011 | Sentry Fireproof Safe
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
Sentry safe
u can request a lost combo from the sentrysafe.com u gotta get a it noteiatized and send it in to them the details are listed on the webpage i hope this helps u
Aug 25, 2007 | Sentry Fireproof Safe
Supra 001004 Push Button Lock Box Key Safe Logo
93 people viewed this question
Top Supra Home Security Experts
Lawrence Oravetz
Are you a Supra Home Security Expert? Answer questions, earn points and help others
