Question about Garden
Mcculloch petrol strimmer
I have a McCulloch petrol strimmer I replaced the cutting head and now it isnt running at the right speed it is turning slow
    Sergeant:
  • 342 Answers
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
Posted on May 30, 2014
4 Suggested Answers
  • 653 Answers
SOURCE: mcculloch petrol hedge trimmer, no petrol seems to be getting
There should be a strainer on the fuel intake line in the fuel tank. Take it out and clean or replace it, and check the fuel lines for cracks or leaks. If this doesn't fix it, disassemble and clean the primer button. There should be a little one way flap valve that opens to allow fuel to be sucked in from the fuel tank and closes to push the fuel into the carburetor.
Posted on Jun 06, 2009
1joester2
  • 74 Answers
SOURCE: What petrol/oil mix should be used in a McCulloch
The specified ratio is 40:1
40 parts gas, 1 part oil.
Posted on Jul 09, 2009
  • 47 Answers
SOURCE: stihl strimmer engine runs but wont cut grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Posted on Apr 07, 2010
How to load new cutting line onto a McCulloch Strimmer TM250
You can probably find a Youtube demonstration video.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jul 16, 2014 | McCulloch 41201-33 Line Head, Models...
Mcculloch mt270 strimmer cuts out when I press the trigger
Carburetor needs replacement. Possibly primer bulb assembly as well.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 26, 2012 | McCulloch Garden
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Why wont my mcculloch tm210 strimmer run unless its on choke,once you turn the choke off it stalls
Because your carburetor is out of adjustment and/or needs to be replaced.
Contact us
User manuals
McCulloch Service
Jun 18, 2012 | McCulloch Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Hi wev put the bit on for the line onr mcculloch tm 250 petrol strimmer. Can u tell me how you get it back off thanks
Hold the big alloy nut above the trimmer head with a suitable spanner, then turn the whole head anti clockwise as you look at it whilst holding the nut, the complete head will spin off.
Apr 28, 2011 | Garden
Mcculoch mt 300mcculoch petrol strimmer carb two adjustable screw bolts ones for petrol, ones petrol & air mixture hich one does which
Actually both screws are for petrol mix. The screw closest to the engine is the Lo side. Lo side jet provides petrol at idle and during the ramp up to speed. Hi side jet (closest to air filter) only effects the mix at high speed.
From McCulloch, these were set at 1 1/4 turns out.
Sep 16, 2010 | Yard Machines Garden
Mcculloch strimmer/brush cutter - cuts out when throttle opened
Hi sounds like it could need a diaphram kit in the carby if it has mixture screws one markedl for low speed and one marked h for high speed you can try winding out the low speed screw a bit but if that does not work it will definatly need a kit.
Jul 25, 2009 | Garden
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
