Question about Uniden BC72XLT Handheld Scanner
Won't pick anything up (uniden BC72XLT)
I've had this thing for a while and now so I can't return it. Everything seems to be working fine except it picks up nothing, it scans properly, etc. I have good frequencies programmed in it but it doesn't seem to be working...just scans away and away. I have the squelch set properly too. I know this because I have another scanner that is picking up signals right next to this one. It's frustrating because I've never heard a peep out of it other than setting the squelch and the beep when I turn it on. Anybody know some secret thing that I don't have selected or something? Thanks.
  • 22 Answers
Not sure this would be a solution but...
Make sure you don't have the Ch. Locked out so it just skips them..
You may also try and let the scanner sit on one frequency that you know has chatter and see if you receive.
This unit also picks up local weather try that feature and you can tell if you reception is working or not.
Posted on Jul 24, 2009
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
I was on a webpage this morning and everything was fine. When I moved my mouse, the screen turned pink (all the way into the explorer bar, not just the webpage) with something that looked like a barc
when you say you've reset the drivers, what do you mean?
you may need to download and install a new driver for your display adapter as the installed driver may have become corrupted.
Mar 09, 2012 | Toshiba Computers & Internet
I was given a Meade DS2130 reflector. Everything seems to work fine except the scope doesn't move in Altitude. The motor works fine and the white horizontal worm gear and vertical white gear turn...
ONLY Meade will have parts-- usually they want you to return the mount to them for repair-- call them here:
http://www.meade.com/support/index.html
www.telescopeman.org
www.telescopeman.us
Aug 28, 2011 | Optics
How do I get it off manual scan uniden bc72xlt when i turn it on it won't scan. thanks need help.
these scanners are a little hard to operate i have one of these it took me a while...Ok its because you have it on hold.when you turn your scanner on press your scan button.and your scanner should start scanning...
Jul 09, 2011 | Uniden BC72XLT Handheld Scanner
How do i reset my Uniden BC72XLT? I have unwanted frequences programed inside..
To reset the BC72XLT:
- Power the scanner OFF.
- Press and hold the 2, 9, and HOLD keys while powering the scanner ON.
After about 3 seconds the word CLEAr will show on the display.
The above will delete/erase all of your programmed data. If you don't want to lose everything, you can just program 0.0 (zero decimal zero) in place of each unwanted frequency. That will clear those channels and they will be skipped during SCAN.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
Bill B.
Listening in since the 60's
Feb 26, 2011 | Uniden BC72XLT Handheld Scanner
Well my scanner don't pick up any thing any more the Squelch don't turn off to hear anything what can i do to fix it, and all it all worked befor but now it's the Squelch
Hi, my name is John. Check your antenna, try a different location, make sure it is still programed on the frequencies you have in it, some may have changed frequency and you did not know it.....hope this was helpful....Rate this solution on the four thumbs-up.....John
Sep 10, 2010 | Uniden BC72XLT Handheld Scanner
Microwave not working (generating heat)
Please check the door switch for proper operation.
May 19, 2010 | Frigidaire PLMV168 Microwave Oven
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Bc72xlt handheld scanner
No. The BC72XLT accepts keyboard programming only. For detailed instructions you can download/print the operating manual here:
BillB
Feb 07, 2010 | Uniden BC72XLT Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
445 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
