Question about Marvin 1210 Floor / Box Fan
Honeywell hw628 fan apart - Marvin 1210 Floor / Box Fan
I just bought the Honeywell Quietset 8-Speed tower fan (black and silver on top). I installed it correctly but the fan is extremely loud and squeaky and can hear the inside pole that rotates the fan, even...
STOP! Before you take anything apart, turn fan upside down and find the large plastic "screw"(cord passes through it)that secures the fan to the pedestal. Is same color as unit. Loosen it and see if squeaking stops. Worked for me!
Mine was driving me nuts and I was prepared to return it to store.
Aug 30, 2011 | Honeywell Comfort Control Tower Fan -...
How to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Apr 15, 2010 | Honeywell Dryers
Fan has become noisy. Does the fan need to be cleaned? Can I take it apart to vacuum the inside?
if the fan is noisy it can be two dirt or grit affecting the propeller or the baring on the motor shaft
Aug 23, 2009 | Honeywell Dryers
Loud screeching sound from window fan.
There are two bearings in most motors.  One is at the base of the fan blade where the shaft goes into the motor.  Try lubricating this with a small amount of household oil.  If your lucky, this will stop the problem.  If not, the bearings have worn and the unit will need replacing.
Nov 15, 2008 | Honeywell HW628 Window Mount Fan
Is there any way to take back off to clean???
I had the same problem. I called Honeywell and they told me that it was designed so it could not be removed and I would have to send it in for repairs. When I told them it only needed cleaning, the woman told me they won't do that and I should by a new one. Right. So, I took it to Home Hardware and they were very helpful. Apparently, the screws at the back require a special screwdriver that is not sold to the public. But, they did it for me and replaced them with common screws. Now I can open it and clean to my hearts content.
Jul 08, 2008 | Honeywell HW628 Window Mount Fan
I fully extended the extender panels on my Honeywell HW628 Twindow Dual Window Fan and can't get them to shrink back to fit my window. Please help.
Most likely they have popped out of their bottom channels. You will need to get them back in to be able to open the panels. Good Luck!
May 27, 2008 | Honeywell Heating & Cooling
Marvin 1210 Floor / Box Fan Logo
Top Marvin Dryers Experts
Are you a Marvin Dryer Expert? Answer questions, earn points and help others
