Pump won't turnover.
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
SOURCE: Campbell Hausfeld PW1380 Pump won't run when water hose is connec
http://www.ppe-pressure-washer-parts.com/campbell-hausfeld-pw138000-pressure-washer-parts
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
SOURCE: What kind of oil do
The pump uses SAE20 or SAE 30 non-detergent motor oil that fills up about half way
The engine uses 10-W30 motor oil that comes a bit more than half-way up dip stick.
Do not turn washer on its side or upside down to drain oil, or oil will run into carburetor.
If you have problems starting:
read:
http://www.fixya.com/support/t6504468-craftsman_2700_psi_pressure_washer
