Question about Lexmark W840 Printer
What Lexmark W840 fuser? - Lexmark W840 Printer
2 Suggested Answers
Fault 202.02 keeps coming up
Hey there,
The code indicates that you have a paper jam in the system. It may be a small chip or full sheet of paper. It may also be something that fell into the top of the machine. Open front panel and try to locate the offending item. It may be at the fuser outlet or the standard outlet.. Once cleared, the machine should reset itself. just plug in and it should occur automatically.
Oct 03, 2013 | Lexmark W840 Printer
915 service motor error
The error means that the printer is detecting that there is Fuser cooling fan failure. Check if the fuser cooling fan is installed properly. If it is, check the fuser cooling fan for operation. Follow the steps below:
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Fuser cooling fan.
Does the fuser cooling fan RPM increase? If yes, perform a print test, and if the error continue, replace the printer engine card assembly. If no, check the fuser cooling fan for proper connection.
Nov 30, 2012 | Lexmark W840 Printer
Replace pc unit problem on Lexmark W840 Laser Printer
Here is an excerpt I found from the W840 user manual. Looks like you need to change the photoconductor kit. Here is the link for the user manual: images.lexmark.com/publications/pdfs/w840/eng/ug.pdf
To ensure print quality and to avoid damage to the printer, the printer stops operating after the photoconductor kit has reached approximately 60,000 pages (Letter/A4). The message 84 Replace PC Unit is displayed when the printer reaches this point. If the Toner Alarm setting is set to Single or Continuous (default is Off), the printer automatically notifies you before the photoconductor reaches this point and displays the message 84 PC Unit Life Warning. To avoid having the printer stop operating, replace the photoconductor kit when you first receive the 84 PC Unit Life Warning message. Once the photoconductor kit has been replaced, normal printer operation resumes
Apr 11, 2011 | Lexmark W840 Laser Printer
Getting a 80 Maint. Error. Replaced the fuser. How do I reset the paper count?
Go to Config by turning off the printer. Then press and hold Select and Return buttons while turning on the printer. Once in Config Menu, choose Reset Maintenance Count.
NOTE: The error indicates that the printer has already printed 300k pages, worn out transfer and charge rollers. You should've replaced the maintenance kit = fuser, charge roll, transfer roll and pick tires. Otherwise, you'll ge having print quality issues.
Jun 15, 2010 | Lexmark W840 Printer
Service fuser 920.00
This means your fuser temperature is not correct. You have to replace the fuser.
Jan 26, 2010 | Lexmark W840 Printer
920.00 SERVICE FUSER ERROR
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs almost as much as the printer, so I think you would be better off getting a new printer unless you find a cheaper or a second hand fuser on Ebay.
Oct 05, 2009 | Lexmark W840 Printer
Lexmark W840 phantom paper jam
Hi! In your case, did you open already your printing?. Because there's still particles left in your printer, usually in the heater roller. consulting to a printer technician is the best way to solve this. GOOD LUCK, thanks
Mar 20, 2009 | Lexmark W840 Printer
Lexmark W840 Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
