Question about Polaris Pb4 - 60 Booster Pump
Where is reset button in polaris motor - Polaris Pb4 - 60 Booster Pump
    Top Expert:
  • Polaris Master
  • 8,686 Answers
No reset if blows breaker need new one
Posted on Apr 23, 2016
Polaris pool pump wiring
check voltage with a meter if ok and you check your wiring could have a bad motor from factory double check first
Aug 11, 2012 | Polaris Pb4 - 60 Booster Pump
I just installed a new booster pump for Polaris 280. It runs hot and it doesn;t seem to have enough pressure to make the sweep run. Any suggestions
Thank you for posting your question here on Fixya.com.
When you installed it were you careful to set the motor to the correct incoming line voltage? If not and you are powering it with 115V you probably didn't reset the motor for 115 from 230...factory set motors come out for 230 V. A motor set for 230 but running on 115 will be very hot and over time will begin to cycle its overload. The performance will be poor until corrected. Look for a dial in the terminal area or wires to be reconfigured. Directions for how to set the motor voltage should be found on the motor nameplate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Mar 06, 2011 | Polaris Pb4 - 60 Booster Pump
I have a 1999 Polaris Sportsman. I just put a new drive belt on it. It is now very difficult to shift and when I do, it wants to take off without giving it any throtlte. It often stalls when I stop...
check you buttons and fly weights on your primary clutch (motor) possbly wrong belt or a broking spring or buttons are gone in the secondary (transmission clutch) broken helix in secondary..........pull clutches and have them inspected
Jan 13, 2011 | Polaris ATV
Just bought a new polaris booster pump (PB4-60) and installed it...the polaris ran for a few seconds and shut off.
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
Apr 14, 2010 | Polaris Pb460 Polaris Booster Pump...
Is there a RESET button on this pump PB-4 . Nothing happens when we turn power on.
NO, there is not a reset on these types of motors. Check for proper voltage at the motor connections. Make sure you have it properly wired for the rate voltage of the motor.
Apr 04, 2010 | Polaris Pb4 - 60 Booster Pump
Installed a new 3/4 hp Polaris pool sweep pump.
Check your voltage and be sure it matches the way the motor is wired. You will find a scematic for this on top or on the side of the new motor, with a diagram on how to rewire it if nessary. If this is not the problem then it is in the motor and should be returned for a new one.
Dec 19, 2009 | Polaris Pb460 Polaris Booster Pump...
My polaris booster pump does not run when turned on. is there a reset button other than the circut panel?
there is not a reset on the pump itself. It does have a high limit that shuts the motor off if it overheats but will reset on it's own when it cools down. Check to see if it might be tied in with a GFCI or a sub-breaker somewhere.
Nov 10, 2009 | Polaris Pb460 Polaris Booster Pump...
Motor misses out and backfires when (trying to backup) ATV 4x4
Polaris quads have a reverse override that does not allow full power in reverse unless you push the override button on the left hand handlebar. Prevents you from going full speed in reverse and wiping out. You will also notice that your 4x4 will not work unless you push the button,
Mar 18, 2009 | Polaris ATV
Polaris Pb4 - 60 Booster Pump Logo
263 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
