Question about B&K Plumbing
How to install b&k lavatory faucet 121-024 - B&K Plumbing
5 Suggested Answers
  • 82 Answers
SOURCE: I just installed an american standard faucet
Silly question, but did you turn the shut offs back on after installing? If so, the aerator is probably clogged (the screen on the faucet). Unscrew it and clean it out. Good luck
Posted on Dec 31, 2009
motor1258
  • 6674 Answers
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Posted on Jan 22, 2010
  • 349 Answers
SOURCE: How do I install the Moen 10790 Lavatory Faucet
This in link below had a detailed instruction on how to install your drain.
http://www.ehow.com/how_2342611_install-sink-pop-up-drain.html
This link below has a parts view of how it goes together. If you will look the waste seat will be the peice that will go in your sink up top and everything esle underneath.
http://www.plumbersurplus.com/pdf/02535.pdf
Posted on Jun 20, 2010
Dplumber
  • 119 Answers
SOURCE: How do I remove handle
There should be a small hole under each lever handle. Inside the hole is a handle setscrew. Use a 2.5mm hex wrench to loosen, not remove, the setscrew. turn the screw counter clockwise to loosen, and then the handel should just pull straight up and off the faucet. Here is a parts breakdown for the PRICE PFISTER Treviso Wide Lavatory Faucet T49-DK00.
Posted on Sep 08, 2010
Do you have a handle set with a 7 inch spread instead of a 8 3/4 spread and model #
Yes we do. how many would you like?
  • Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount ... www.amazon.ca/Kingston-Brass-CC543T8-Vintage-7-Inch/dp/B0026ZPI0Y
    • KINGSTON BRASS
    Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount Leg Tub Filler with Hand Shower, Satin Nickel in Showerheads & Handheld Showers.
  • Kingston Brass KB967 Magellan II Widespread Lavatory ... www.amazon.com > ... > Rough Plumbing > Faucet Parts > Faucet Handles Kingston Brass KB967 Magellan II Widespread Lavatory Faucet 8-Inch to 16-Inch Centers 7-Inch Spout Reach, Satin Nickel and Polished Chrome
  • images of 7 inch spread faucet bing.com/images th?id=oip.m9aaf750d3da8ce6a24cbe32ef9078ae8o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m643aef6e35c24789db3419b21dd47a91o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.ma09426c72dcc25d64ff92045ab194af1o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9b0dc70d9ab53ad1ecca18fd130db74bo0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9afd6495c16d35699054f30b9ee4d7e7o0&w=104&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of 7 inch spread faucet
  • Water Creation F6-0007-05 Vintage Classic 7-inch Spread ... www.overstock.com > ... > Bathroom Faucets > Water Creation
    • 5/5
    • 1 RATING
    • $409.17
    Shop for Water Creation F6-0007-05 Vintage Classic 7-inch Spread Deck Mount Tub Faucet with 2-inch Risers and Handheld Shower. Get free shipping at Overstock.com ...
  • Apr 16, 2016 | Plumbing
    How do I remove the handle on a Moen Brantford doule handle lavatory faucet
    there has to be a small setscrew hole on either handle .otherwise they could not be repaired
    Feb 11, 2015 | Moen 6610 Brantford Two Handle Lavatory...
    Dripping water unless I totally shut off cold water line.
    If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
    He has a very extensive list of repair parts for faucets.
    Rod
    US Parts Center
    Jan 29, 2013 | Kohler K-12265-4-CP Fairfax Widespread...
    I installed a faucet for my vessel sink and the water is only a trickle, is this normal or should I return it?
    Check that your shutoff valves are open.
    Also, it often happens that debris gets dislodged and blocks the valve.
    Jul 08, 2011 | Price Pfister Ashfield Single Control...
    I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
    I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
    Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
    How do I remove handle of lavatory faucet to replace cartridge? The faucet is dripping and making a noise
    Sep 07, 2010 | Price Pfister Treviso Wide Lavatory Faucet...
    I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
    Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
    Aug 28, 2010 | Price Pfister Plumbing
    How do I install the Moen 10790 Lavatory Faucet drain assembly brass Chrome
    Jun 20, 2010 | Moen 10790 Lavatory Faucet drain assembly,...
    I just installed an american standard faucet Molel# 2808.222 Called SPREAD LAVATORY FAUCETS . The water does not come out. can you please help me?
    Dec 31, 2009 | American Standard Kitchen Faucet 6310 020...
    Pegasus faucet problem
    The part you need can be purchased at Home depot
    Jan 07, 2009 | Pegasus Technologies Widespread Lavatory...
    Plumbing Logo
    81 people viewed this question
    Top B&K Plumbing Experts
    Tom Chichester
    Bill Boyd
    Daryl Gleaton
    Are you a B&K Plumbing Expert? Answer questions, earn points and help others
