Question about JVC Car Audio & Video
My jvc kd-g731 always stays on and finished my car's battery
etirbynnor
  • 655 Answers
SOURCE: How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
Posted on Jun 01, 2009
kenw392
  • 2226 Answers
SOURCE: JVC car CD KD-R301does not retain time
sounds like you do not have the yellow wire connected to a constant power source. you need to connect the yellow wire to a source that is still hot when the key is switched off.
Posted on Dec 30, 2009
Testimonial: "Thanks, I will try that!"
kenw392
  • 2226 Answers
SOURCE: JVC model KD-S6060 car CD/radio. Not working.
have you tried the source button????????
Posted on Jun 16, 2010
  • 22 Answers
SOURCE: having disconnected my car battery I now need to
For the numerical code given, enter it using the am/fm presets buttons. Please note, if you try too many times the radio will lock up for a certain amount of time.
Posted on Mar 04, 2011
SOURCE: turn off demo mode on a jvc kd-g333
I need a code JCV KD-G333???
Posted on Mar 16, 2011
JVC KD-R810 power wont stay on
If it was working early, then it is failed. It needs to be serviced.
If it never worked since you installed, then check wiring.
Feb 08, 2012 | JVC Kd-r810
How do you reset a jvc KD-G340
there may be a reset switch, which will be a small hole about the size of a pencil tip. if not you can always disconnect the battery for a few minutes.
May 06, 2010 | JVC KD-G430 CD Player
How do I set the time on a JVC KD-S13 car stereo?
Press and hold 'SEL' button. DEMO is displayed. Use the up or down to select an item. Turn volume knob to set/adjust. The clock is next after demo. set hour then minute press SEL to finish. Reference page 3 in this link to JVC for your KD-S13 CD Receiver Instructions.
http://books.jvc.com/Download/975469902/GET0400-001A.pdf
Dec 27, 2009 | JVC Car Audio & Video
Just installed jvc kd-s16 and it loses power after 5 seconds. Used proper wiring harness and installed in 1996 f150
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Dec 27, 2009 | JVC AM FM CD DET FACE CAR STEREO
Jvc cd player model kd-g120,how do i set the time?
Press and hold 'SEL' press down arrow until CLOCK H is displayed rotate Volume knob to adjust press down arrow once to display CLOCK M rotate Volume knob to adjust press 'SEL' to finish. Reference pages 6 and 10 in this link to your JVC KD-G120 Instructions Manual.
http://resources.jvc.com/Resources/00/00/91/GET0330-001A.pdf
Nov 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
Oct 19, 2009 | JVC KD-G310 CD Player
Don't know how to set the clock on my jvc kd-g240/kd-g140 car stereo
press and hold the sel button until the menu pops up then scroll through til you see clock settings.
Dec 20, 2008 | JVC KD-G140 Car CD Player
JVC KD-S575
Most versions of the JVC KD-S575 uses the 16pin block connector as shown below. It is available at the JVC Accessory Store.
Below image shows the pin's alphanumeric designation.
Color coding and where connected is shown below.
A2 Brown - cellular phone/mute
A4 Yellow - Always on B+12 (such as the battery's positive terminal)
A5 Blue/White - Power Antenna
A7 Red - Accessory or switched +12VDC
A8 Black - Chassis/Ground/GND
B1 Purple - Right Rear +
B2 Purple/Black - Right Rear -
B3 Gray - Right Front +
B4 Gray/Black - Right Front -
B5 White - Left Front +
B6 White/Black - left Front -
B7 Green - Left Rear +
B8 Green/Black - Left Rear -
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | JVC KD-S570 CD Player
Car Audio & Video Logo
43 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
