Question about IBM xSeries 346 Server
Drive does not contain a valid boot sector - IBM xSeries 346 Server
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 196 Answers
Sounds like your disk is crashed. Get help from a disk recovery company such as www.data365.com.au
Posted on Aug 10, 2014
Boot up xp get the.... File:\Boot\BCD Status:0x0000098 Info:The windows Boot Configuration Data file does not contain a valid OS entry.
try putting your XP disk in the drive and shut down then restart system many times it will find what it needs and go to working again
Apr 17, 2015 | Computers & Internet
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
Can I fix my Seagate hard drive to bootable?
Hi, two things to try.
1. If you have the Win7 cd/dvd, go here and read:
http://www.bleepingcomputer.com/tutorials/start-the-windows-7-recovery-environment/
But I'm thinking that you have a few bad sectors in the HD's boot area (educed from your tzak.tzak description - which is head seek (bang) trying to find the boot sectors). Which I'm not sure that Win7 recovery can cope with. But check out this link and read/follow links:
https://answers.microsoft.com/en-us/windows/forum/windows_7-system/how-to-fix-the-boot-sector-of-windows-7/deb6ad12-a6b1-46fc-9786-240f66f9143e
And this link (better?):
https://answers.microsoft.com/en-us/windows/forum/windows_7-system/restoring-windows-7s-master-boot-sector-to/435f7bf7-9d5b-4741-9746-945ff06e6251
or
2. Go here and get SystemRescueCd:
http://www.sysresccd.org/SystemRescueCd_Homepage
It contains many tools for the repair of malfed systems.
You will want to use this tool: TestDisk
TestDisk[4]
Popular disk recovery software. Recovers lost partitions and repairs unbootable systems by repairing boot sectors. It can also be used to recover deleted files from FAT, NTFS and ext2 filesystems. File system recovery is supported for reiserfs, ntfs, fat32, ext2/3 and many others.
In closing, I would get a new HD, maybe a SSD? to replace your original hard drive (It may be failing, or it took a hard knock while in the boot phase, causing head-bang in the boot sector - not good). Make the new drive your master and use the old one for misc. data that you have originals of, i.e. music cd's, dvd movies, programs off-loaded from Tivo/DVR, etc.
Hope this at least gets you going in the right direction...
Oct 25, 2014 | Seagate BARRACUDA Computers & Internet
Error 58 unable to write to boot sector
Run CHKDSK, if you see a message "The drive contains one or more unrecoverable problems", you need a new hard drive.
If you cant get on to Windows try a fresh install. If that fails buy a new HDD should fix it.
Nov 26, 2011 | Sony VAIO VGN-A230P PC Notebook
BOOTMGR IS COMPRESSED
Validate and Fix the File System
This runs the check disk program to detect and attempt to repair problems on one partition. For example, to repair the C: drive:
At the prompt type chkdsk c: /r
Repair the Boot Process
Typically this is used if Windows doesn't start and you can't get to the safe mode menu. You might also replace the Master Boot Record (MBR) and boot sector if you suspect a virus infection. There are four options:
New MBR - Insert a new generic MBR without changing the partition table.
At the prompt, type: bootrec /FixMbr
New Boot Sector - Insert a new Windows 7/Vista compatible boot sector. It will automatically insert the right type of sector for the file system type (NTFS, FAT32, etc.)
At the prompt, type: bootrec /FixBoot Rebuild BCD - Rebuild the Boot Configuration Data (BCD). The BCD controls which partition boots. This option will let you select which installations to include in the BCD.
At the prompt, type: bootrec /RebuildBcd Find OSes - Scan the system for all OS installations that are compatible with Vista/2008 and will also show those that are currently included in the BCD.
At the prompt, type: bootrec /ScanOs
in the end type in C:/expand bootmgr temp
Aug 24, 2011 | Computers & Internet
My dell latitude 620 is not accessing hard disk, giving report of 'No Boot sector'
> no Boot sector
A computer "boots" by reading the first few sectors from the diskette (or CD-ROM) or disk-drive, and then running the software that just was read, to "kick-start" the whole process of starting Windows.
Thus, "no boot sector" could mean:
* the disk could not be read at all,
* the information was read from the disk, but it was recognized as being a valid computer-program
So, it's possible that your disk-drive is "dying".
Take your computer to a computer-store, for more trouble-shooting.
Oct 22, 2010 | Dell Computers & Internet
I install and bootcamp and resize the disk to 160gb. then i accidentally put the cd in the USB external cd drive. i forgot to put it in the Imac g5 cdrom drive. when i boot up.. its a mess my mac os x not...
I understand your problem to be that at the time you were executing the critical reboot just prior to installing Windows with Boot Camp, you placed the Windows CD into the wrong optical drive. Now your machine is stuck at the gray screen and is not responding to anything and will not boot from the system DVD
I have encountered this problem previously. The solution is to boot from an external drive containing a valid copy of the Mac OS. Although your machine will not boot from a DVD at this point, it WILL boot from an external drive if you hold down the Option key after you hear the startup chime, and select that drive's icon when it appears. Once you have successfully booted, go to System Preferences / Startup Disk to select the Mac partition of your internal drive, and your machine will reboot normally.
This leaves only the question of how you obtain an external drive containing a valid of the Mac OS. Some options are 1) a cloned backup drive, 2) another Macintosh via "Target Disk Mode," or 3) have someone create you such a disk from another machine. On the plus side, this solution involves no loss of your data, which makes it worth pursuing.
Nov 15, 2009 | Apple iMac G5 Desktop
Windows
You may have a boot sector virus. At my bench I would remove your hard drive and install it on one of my towers and run a virus scan on your hard drive. Recovery from a boot sector virus is very difficult using tools found in Hiren's Boot disc, a cdrom that contain various programs to recover a hard drive.
Lastly, you may simply have lost the boot strap loader (even though this doesn't make any sense if you have used your recovery CD and recovery partition with success. If you boot and hear a beep, press F8 repeatedly immediately after the beep and you'll receive the recovery bootup option screen, choose Safe Mode first and see if that works, if not choose last know good configuration and otherwise if offerred choose use System Restore.
If all this fails you as a user you need service from a professional.
Hope this has helped or fixed ya.
Worldvet
May 16, 2008 | Computers & Internet
I cant identify the prolem
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
May 07, 2008 | Computers & Internet
IBM xSeries 346 Server Logo
148 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
