Question about Fujioh BUF-03R Kitchen Hood
What fuse is it that works my volkswagen polo headlights
Kindly help with the fuse layout for VW Polo Classic 2007 as my headlights' bulbs keeps on blowing up and I am not sure what could be the cause. maybe its the fuse ?
cant put your fingers on the glass of the headlight bulbs when fitting
they will blow straight away
could be a faulty earth wire
for a large headlight fuse to blow will be a wire shorting to the an earth or chassis somehwere
Sep 17, 2016 | Volkswagen Polo Cars & Trucks
Fuse for the right headlight
Need to verify
Perhaps. Fuse 36, 7.5A - Right main beam bulb
Jun 04, 2016 | 2010 Volkswagen Polo 1.6
Where is the fuse for the cluster polo playa 2001?
How to access the fuse box in a Volkswagen - YouTube
? 1:17
https://www.youtube.com/watch?v=Nr-TKfDhw8c
Dec 5, 2012 - Uploaded by Jay Pichardo
where do I find the fuse values for a vw polo 2002? in the manual there ... hello need to know how to make ...
vw polo fuse box layout - Volkswagen Forum
Dec 10, 2015 | Cars & Trucks
Hi, Both my headlights on my polo have just stopped working. No warnings. All interior lights, fog lights and side beams are working fine. I had one of my headlights replaced 2 months ago so can't imagine...
It sounds like you have a short. As for the headlights go through owners manual to locate the main relay for the headlights in the power distribution box.
Feb 28, 2015 | 2009 Volkswagen Polo 1.4
2005 volkswagen polo 1.2 left hand headlight not working after replacing bulb
Hi. Thses bulbs are quite difficult to fit in the correct position. If you are sure that it is seated corectly, check the fuse. if there is power on the wire at the bulb then recheck the bulb seating.
Jan 14, 2014 | 2005 Volkswagen Golf
Vw polo fuse box layout 2004
you might find the fuse diagram on the inside of the fuse box cover under the hood.....hope this helps.....cheers
Jul 26, 2010 | 2004 Volkswagen Golf
My polo main headlights do not work but my full beam does work
Hi, the main headlights work through a separate fuse from the full beam. If all the fuses are fine the problem might be that the globes has blown on the vehicle. To make 100% sure that it is the globes, see if you get power to the headlights when the main lights are switched on.
Nov 24, 2009 | 2004 Volkswagen Golf
CAR FAULTS
try disconecting the battery completely for about 30 minutes you may get lucky and not have blown the computer. You may also want to change the fuses anyways , sometimes they look good but are still bad.
Aug 03, 2009 | 2000 Volkswagen Golf
Fujioh BUF-03R Kitchen Hood Logo
56 people viewed this question
Top Fujioh Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Fujioh Kitchen Range Expert? Answer questions, earn points and help others
