Question about Toys
Need instructions for 2001 play skool item # 08769 helmet and steering wheel
3 Suggested Answers
SOURCE: replace original steering wheel
im looking for airbags nissan altima 2003
Posted on Jan 07, 2009
  • 11 Answers
SOURCE: 2001 mercury cougar steering wheel?
Don't listen to that guy!!!! you need to take the plastic cover behind the steering wheel. there are two bolts holding the air bag in t30 (torx) then the air bag falls right off. then the steering wheel is held in by a 15 mm head bolt.
Warning: make sure battery is disconnected for at least 30 min before you mess with the air bag connector
Posted on Apr 02, 2009
I have excessive play in my steering wheel and a creaking noise when turning the wheel all the way to the left It sounds like the passenger side I was told I need to get the bushings greased and replace...
do not grease bushes . Excessive play in the steering is an indication that the end float or clearance in the box/rack needs adjusting. The noise I suspect to be a bearing failing and that would account for the play. Stabiliser bars have nothing to do with steering. They are there to stop body roll going round a corner.
Feb 27, 2014 | Cars & Trucks
2001 Mitzubishi Montero Sport Steering Box
The steering box has an adjustment screw or bolt which is kept from turning by a lock nut. Loosen the lock nut and turn the screw or bolt
so as to reduce the play in your steering. The adjusting bolt is generally
located on top of the steering box.
Jan 04, 2013 | Cars & Trucks
How do you replace the turn signal light in a 2007 Chevy Equinox LS
most likely it is built into a multifunction switch which mounts under the steering wheel. so you have to pull the steering wheel in order to replace the switch. this is kind of tricky as there is an airbag in there, should be done by a trained tech. wear a motorycle helmet when you start jerking on the steering wheel to remove it without a proper puller.
Jan 12, 2011 | 2007 Chevrolet Equinox LS New Cars
Steering wheel locked. How do i unlock it?
go to mitchelldiy online for complete instructions. As far as we know your a thief asking for a nontraceable instructions on how to steal a car. Mitchelldiy will want a credit card and 10 bucks. This way were not liable.
Mar 31, 2010 | 2001 Ford Mustang
Steering is loose, lots of play in steering wheel
you need to do what i call a dry check i do before performing an alignment have someone sit in truck and shift steering wheel from side to side lightly while you look at steering components check for loose pitman arm,drag link if used inner tie rods outer tie rods or excessive play in steering box then jack up each front wheel and check upper and lower ball joints
Mar 18, 2010 | 1992 Ford Bronco
I own a 2001 RX300 and am noticing a bit of free play in the steering wheel when wheels are straight and the vehicle is moving. Also feel a vibration when driving around 70mph. The tires are ok and...
It sounds like a worn steering rack bush in the steering rack,as this explains the play youve mentioned,the vibration is caused by the wheels moving very slightly through the play in the rack bush,theres 1 letf and 1 right side bush in the ends of the steering rack that would need checking for play or movement
Nov 10, 2009 | 2003 Lexus RX 300
Our jeep grand cherokee has very "loose" steering. Just a small bump in the road and it's very hard to control the wheel. Our mechanic says he can't find anything to fix, but it seems to be getting worse...
Sounds like you have the beginning of what is fondly called "death wobble"
This condition can be caused by overall play in the steering components (small amounts of play added together = more play than you would want in steering, and loss of wheel control on bumps at speed (usually over 55mph) The major items to look at first art track bar bushings and mounts, ball joints and believe it or not, proper wheel lug torque. Other items are steering box to chassis mounting and wheel alignment. Caster can be adjusted in a more positive direction (beyond factory) which causes the wheels to "want" to remain straight ahead at speed. This can either be done by moving lower control arms or in difficult situations, ball joints are available with built in offset.
Check ALL bushings and pivot ends for any sign of wear, eliminate the items with the largest amount of play first. DO NOT let anyone talk you into replacing the steering stabilizer (sideways shock on the linkage) as a cure...This will cover up the problem for a short time but will not cure it. After the problem has been solved, you should replace that part, because likely it has been beaten to death while the condition was present.
Aug 08, 2009 | 1995 Jeep Grand Cherokee
Logitech steering wheel is not steering...all other buttons working trying to play nascar driving....do not have instructions manual
Go into controller settings in the nascar 09 game and select the steering wheel setup that is correct for your wheel.
Jun 26, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
2001 Dodge intrepid steering console
I have done this in dodge a mini van
same set up
disconect the battery
reomve the 4 / 10 mm bolts from the back of the steering wheel for the airbag.
lift the airbag from the wheel.
remove the plug in for the bag.
then there is a 18 mm bolt for the steering wheel nut to remove
then you need a wheel puller to remove the steering from the shaft.
then you will see the brass contacts on the clock spring.
this you Will see built up with hair and dust and will need to be cleaned.
reverse to put back together.
not to many parts.
RD
Jan 13, 2009 | 2001 Dodge Intrepid
Toys Logo
37 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
