Question about iPhone Apps
Thief (dark) in scriptorium 2nd time around, how to exit?
Thief mode
are there other buttons by the power button you could fool around with?
Feb 01, 2013 | Gateway 24" Widescreen Flat Panel TFT LCD...
****** studders from 1st to 2nd gear
Transmission should be serviced with new filter and oil every 50k or so. If you missed the one at 50k, and by the dark fluid I'm guessing you did not do it at 100k, you likely need a new transmission.
Apr 17, 2012 | 2003 Chrysler Town & Country
I pressed 2nd key and up and then held up and hit clear and eventually the screen went dark how do i fix it?
Press and release the 2nd key. Press and hold the down-arrow key. If you go too far this time, press and release the 2nd key, then press and hold the up-arrow key.
Apr 08, 2010 | Texas Instruments TI-84 Plus Silver...
My texas instruments ti-86 is dark all the time, help me please
After changing the batteries the calculator is restored to factory defaults, but the screen contrast may change. The screen may be too light to see anything or., as in your case too dark.
To lighten screen
Press [2nd] key and release it.
Press and hold [DownArrow] until screen is light enough.
To darken screen
Press and hold [UpArrow] until screen is dark enough.
Hope it helps.
Thank You for using FixYa and for rating the solution.
Dec 04, 2009 | Texas Instruments TI-86 Calculator
My TI-86 calculator doesn't have a cursor. I can turn it on and adjust the contrast from dark to light but no cursor appears and nothing comes up when I punch any of the buttons!
Press [EXIT] or [2nd][QUIT] to terminate the program that may be hung in memory. Press [2nd] MEM[F3][F1][F4].
You may have to reset contrast.
1.Press and release [2nd] key.
2. Press and hold [UpArrow] to darken or press and hold [DownArrow] to lighten it.
Hope it helps.
Aug 15, 2009 | Texas Instruments TI-86 Calculator
Fault code J50 & dark strip.
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
May 18, 2009 | Office Equipment & Supplies
Screen is very dark
Try 2nd and all the way down arrow
Jan 21, 2009 | Texas Instruments TI-86 Calculator
Light/Dark Screen
Turn on the TI 83 enter 1234
1. press the <2nd> once; press and hold the <up-arrow> until you get the numbers as dark as you want. If you let up and press the arrow key again you have turned the function off. You must start over by pressing the <2nd> key then the <up-arrow> key and hold.
2. If the numbers are too dark; press <2nd> once and hold the <down-arrow> to get it corrected.
3. If this does not correct the light/dark screen condition you need to buy new batteries!
Hope you can follow my explination.
R. Meidell
Oct 15, 2008 | Texas Instruments TI-83 Plus Calculator
Dark screen
hit second and the down arrow to change screen darkness
Apr 30, 2008 | Texas Instruments TI-85 Calculator
TI 84 Won't turn back on
Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL, reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Jan 11, 2008 | Texas Instruments TI-84 Plus Silver...
iPhone Apps Logo
Top Apps Experts
Lesley Cameron
Lesley Cameron
Are you an App Expert? Answer questions, earn points and help others
