Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a Mitsubishi WD-62525 the timer light keeps blinking and the t.v. won't stay on
  • 3 Answers
SOURCE: Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Posted on May 07, 2009
SOURCE: WD 62725 Timer geen light keeps blinking
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
Posted on May 30, 2009
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
  • 64 Answers
SOURCE: mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Posted on Aug 01, 2009
SOURCE: Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Posted on Feb 09, 2010
My Mitsubishi tv model wd-62525 not on the light of timer is linking
If one light is blinking (lamp light?) remove and inspect lamp to make sure it is in correctly and not shattered. If the set has a recessed reset button on front (if set is unplugged and plugged back it should blink green for about 70 seconds and go out) you may have a issue there.
The model indicated here has a host of problems.
May 20, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My wd 62525 has a blinking timer light and wont power on
do the timer come on at all whean you plug it in do you hear kind of noses? if not take it to a sevice shop
Nov 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light keeps blinking
Have you done a re-set on the TV at all?
Jul 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
15 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
