Question about Baumatic BWE40 Wine Cooler
E2 error on bwe40
I have an error message on my cooler stating e2 can you advise
3 Suggested Answers
  • 48 Answers
SOURCE: BWE40 wine cooler. Is it safe to leave it switched on when code e2 is showing? Does code e2 distinguish which of the two sensors need replacing? Thanks.
e2 is a temperature sensor error code.
You would need a multimeter to test sensor and control board.
Either could be the problem
Posted on May 11, 2014
richardth93715
Hi All,
I had this error on my wine cooler. I checked the sensors and got a reading Kohm from both, however i still decided to replace the rear sensor - buried in the foam. It is located in the foam about 20cm from the LHS and 20cm from the bottom of the foam.
I got the sensors from here https://www.inter-spares.co.uk/?subcats=Y&status=A&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&search_performed=Y&q=49032008&dispatch=products.search
I left the front (internal sensor) and just swapped the two terminals in the 4 way plug. I used normal expanding foam to fill the areas where i had removed the foam looking for the sensor. All up and running now.
Posted on May 22, 2017
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
Hi All,
May 11, 2014 | Baumatic BWE40 Wine Cooler
Danby silhouette dwc276bls e2 error solution
Hi There,
The E2 error codes indicates there is an problem with one of the sensors.
Please contact our customer service department for information on repair.
1-800- 26- Danby
Thanks!
Jul 19, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
What does the message E2 mean...
Certain codes will appear on the display to indicate various malfunctions of the cooler. E. g. if E2 appears in case the fault of the temperature sensor.
Jul 01, 2011 | Amcor PLM-14000E Portable Air Conditioner
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
My printer MP145 display message E2. What does it mean?
E2 errors state that the printer lacks paper.
If the printer does in fact paper which i assume it does, that means that the roller/sensor that detects the paper is defective/bad.
Id recommend replacing as repairing the issue is not really cost effective.
Mar 01, 2011 | Canon Office Equipment & Supplies
Hello, I have BW40 wine cooler. On the display is blinking error message "E2". I have tried to switch off and switch on, but it doesn't helped. Thanks for you support in advance. br, Zoltan
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
Sep 28, 2010 | Baumatic BWE40 Wine Cooler
I own a Palm Tungsten E2 when I go to hot sync I get an error message that states the connection between your device and desktop could be established please check your setup and try again
1. Go to your desktop program
2. Go to top and select HOTSYNCH
3. Select Set Up
4. Select the port your E2 is attached to
5. Theres more but I need to know how you are to this point or go to live tech support and ask for Just_Bobz
Sep 24, 2008 | Palm Tungsten E2 Handheld
Code E2 showing in temparature display
I contacted the technical team at www.baumatic.co.uk and here is the reply I got.
-----Original Message-----
From: Samantha.Codd@baumatic.co.uk [mailto:Samantha.Codd@baumatic.co.uk] On Behalf Of Technical@baumatic.co.uk
Sent: 25 January 2008 13:02
To: Taline Bedrossian
Subject: Re: BWE40 wine cooler
Good Morning.
Thank you for your e-mail.
This error code means that your appliance has experienced a defrost sensor
fault. Please contact our service team on 01189 336 911 to arrange a
suitable time for an Engineer to visit you.
Kind Regards
Quality and Technical Department
Baumatic Ltd
www.baumatic.co.uk
Jan 19, 2008 | Baumatic BWE40 Wine Cooler
Baumatic BWE40 Wine Cooler Logo
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
