Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
Uyii54600455 pc915m12-gl-gls - Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
My car fails to change automatically to another gear and does not display the gears on deshboard
I Your transmission is broken. I would check the shift solenoid first, then the ECU, which is big money. Make friends with a VW mechanic. GOOD friends. You are looking at $500 to 5,000 or more to have that repaired at the dealer. Sorry.
Dec 25, 2014 | 1998-2005 VOLKWAGEN VW PASSAT LOWER CHROME...
Ignition coil firing order for 2000 VW Jetta VR6
Jetta GL & Jetta GLS (two versions with 2.0 l and 115 CV engine)
2000 Volkswagen 2.0 liter SOHC L4 (AEG)
Jetta GLS VR6 y Jetta GLX VR6 (2.8 l VR6 and 200 CV engine)
2000 Volkswagen 2.8 liter DOHC V-6 (ATQ)
Hope helps.
Mar 22, 2011 | Volkswagen Jetta Cars & Trucks
I need to know what kind of motor my 2002 alero has.
2.2 liters 4 cylinder in-line front engine with 86 mm bore, 94.6 mm stroke, 10 compression ratio, double overhead cam and four valves per cylinder
Jan 19, 2011 | 2002 Oldsmobile Alero
My auto locks stopped working gas tank & trunk wont open dome light wot work what caould be wrong??
Welcome to FixYa.com
Need to know before i help-- engine size in liter and is this a GL or GLS ?
Thank you for using FixYa.com
Regards, Lee Davidian
Jan 12, 2011 | 2002 Volkswagen Golf
How can I check the power steering fluid in my 2005 vw jetta automatic 2.0 GL or GLS?
There should a bottle on the left top of your engine with a cap saying POWER STEERING FLUID. open that cap and check if there is fluid in it. Good luck
Dec 09, 2010 | 2005 Volkswagen Jetta
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
