Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Replace mower steering gear shaft
I have a 2003 cub cadet the steering wheel just spins around and around one way and turns the lawnmower some going the other way lt1042/13AX11CG71
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Shaft ha sbrken in steering gear replaceit
Posted on Dec 17, 2014
jmgldsmth
  • 1889 Answers
SOURCE: belt installation for a cub cadet lawn mower
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051
Posted on May 20, 2009
SOURCE: I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Posted on Jul 29, 2009
  • 33 Answers
SOURCE: cub cadet riding mower blade won't turn on
If the click you hear is the electric PTO engaging, then your deck belt is broken or off a pulley some where. Check the belt & then clarify if needed
Posted on Aug 21, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
  • 603 Answers
SOURCE: steering wheel is hard to turn on cub cadet riding
Start buy checking from steering wheel down the shaft , to gear that does turning, to shaft underneath mower that goes to steering tierods , to tires. Oil and grease will do wonders on any parts that look rusty, or may be tight. Definately check air preasure in your tires. You should be fine.
GOOD LUCK.
Posted on Jun 17, 2011
How to make gears/teeth on lower part of steering line up on 268-H T Wheel Horse line up? Rmove deck, orwhat? There is some wear on the teeth, & was bumping last time I mowed. Now, won't turn at all.
There is a spacer/bushing on the very bottom of the steering column. With wear the bushing fails and lets the steering column/and gear on the bottom of it slip down to the point that the gears don't mesh. Replace the Bushing.
Sep 14, 2015 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Have a cub cadet and steering wheel keeps turning but not turning the wheels at all now
howdie sounds like the Gear Box is broken it might need replacing or ther is a shear Pin that is Broke in ther To stop it from moving so might need to be replaced as well
Apr 25, 2015 | Cub Cadet Garden
I need to repair the steering on a Cub Cadet LT 1045 ANY HELP?
there is a plastic coupler the holds the shft to the gear they wear and don't hold the shaft tight to the gear and they jump
Jul 31, 2012 | Cub Cadet Garden
My son was mowing, with our cub cadet 2166, and ran the left front tire into a fence and now the steering wheel wont work. You can turn it and it feels really loose but it isn't connecting to the
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
May 19, 2012 | Cub Cadet Garden
Steering wheel is hard to turn on cub cadet riding lawn mower seems locked up
GOOD LUCK.
Jun 16, 2011 | Cub Cadet Garden
My Cub Cadet riding mower won't turn. It just makes a clicking sound as you turn the wheel??
sounds like teeth on fan gear are worn or steering shaft and gear came away from fan gear. if fan gear worn replace if ok loosen lower steering shaft mount push tward fan gear and tighten, grease front steering spindles. or may need to replace spindle bushings.spindles too tight causing fan gear priblem
Jul 15, 2010 | Cub Cadet 42 And 54 Inch Blade Operator's...
Sounds like the sterring wheel is striped
Sorry I don't have a solution but have a similar problem. I replaced the steering pinion gear in hopes that would resolve the problem, but it didn't. The steering pinion gear is located at the bottom of the steering shaft and turns the steering gear. Looks like the steering gear needs to be replaced as well. The nuts securing the steering gear are accessible in the same area as the pinion steering gear. I am going to order a replacement steering gear and attempt to replace it.
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My Toro LX500 Tractor steering is messed up, the steering wheel spins freely, not turning the tires. Gear looks a little worn. Is there a bushing around that shaft too, seems sloopy
I have just had the same problem.. the steering shaft is held in place only by the deck sheet metal, which has worn & is now too big to hold the shaft in the correct position, funny how a $2 bearing would have prevented this from ruining an otherwise great mower. I'm going to take mine to a mower shop & hopefully they can install a bearing there.
Sep 28, 2009 | THQ The Lawnmower Man
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
131 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
