Question about Garmin Forerunner 110 GPS Receiver
Garmin 110 unable to locate satellites - Garmin Forerunner 110 GPS Receiver
  • 52 Answers
SOURCE: my garmin is takng forever to locate satellites
First, be sure you are outside, in the open when making this diagnosis. Some cars have metallic defrosting layers, which blocks the GPS signal. If, when outside in clear view, you still have problems, try this...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Posted on Jul 18, 2008
SOURCE: Garmin NUVI 660 - can not locate satellite
These are the instructions I got from Garmin as how to do the Master reset:
Here are the steps to backing up the favorites on your unit and then performing the master reset. First, you’ll want to plug your unit into your computer via USB cable. Once it’s plugged in, you’ll want to go to My Computer in your start menu or from your desktop and double-click on the Nuvi. At this point, you should see a few folders, but you’ll want to double-click on the Garmin folder. Here, you’ll want to look for the “GPX” folder and you’ll double-click on that. In this folder, you’ll want to drag and drop the file titled “Current.gpx” to your desktop to copy it. Now you are able to do the master reset.
To do that, you’ll want to start with the unit turned off and press and hold on the upper left hand corner of the touch screen. While holding the touch screen, power the unit on and continue to hold. You should get a message that asks if you really want to go into maintenance mode and you’ll want to select “Yes”. At this point, you’ll want to select “clear user data” and then select “Yes” when it asks you if you really want to clear user data. Now, the unit should restart and you’ll want to take it where it has a clear view of the sky and let it sit for up to 30 minutes to acquire satellites. If after 30 minutes it does not acquire satellites, you can go ahead and reply back to me.
Either way, once we have your unit back working again, you can follow the first set of steps again to get to the GPX folder and drag the “Current.gpx” folder from your desktop to that folder on your unit. This will replace your favorites.
Posted on Oct 07, 2008
SOURCE: I have a Garmin GPS unit which is not able to locate a satellite.
I have a Garmin c330 Streetpilot GPS system. It says that it unable to locate a satellite
Posted on Nov 08, 2008
SOURCE: My Garmin Nuvi 360 lost satellites during use and can't locate
I had the same problem with mine...I shut it down and left it off while giving it a full charge...
Posted on Jan 14, 2009
sharcnet
  • 2130 Answers
SOURCE: Not able to acquire satellite. Garmin stays on
The flip-up internal antenna/GPS receiver is defective and needs repaired/replaced. Please see this link fo rmore info:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Sep 15, 2009
My home base is Ohio. I am now in Texas and my Garmin Nuvi 265W seems unable to acquire a satellite signal for my current location. How can I get a satellite signal that I can use in Texas?
One problem, which I've experienced, are tinted windows (tinted with metal oxide). They block or distort the microwave signal to/from the satellite. Garmin has an optional external antenna which can be used, or you can try relocating the GPS in your car. Try it with all windows down and the unit near an open window. If that works you've confirmed the tinted glass problem.
Jan 18, 2011 | Garmin Nuvi 265W GPS Receiver
Unable to acquire satellites with my garmin forerunner 305. a couple of guys using their 305s were able to quickly acquire.
I find my Garmin 305 is a slug to locate and lock on. But if I pull it off the charger just before I go for a run it locks on all most immediately. Give it a try and let me know if it works.
Jan 19, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin 660 unable to locate satellites. When it does, very unreliable
The flip up Antenna/GPS receiver board needs to be replaced. Please see this link for more info. To much to cut and paste here.
- Jim
Aug 09, 2009 | Garmin Nuvi 660 GPS Receiver
Satellite unacquireable.
never buy magellan there junk lol and the problem you are having is a broken flip out antenna on the back of your unit ..it is common with the older flip antennas just buy a external antenna from garmin and fixed .......if not send it back to garmin because its hardware is bad
Aug 23, 2008 | Garmin Nuvi 660 GPS Receiver
My garmin is takng forever to locate satellites
Hope this helps!!
Jun 16, 2008 | Garmin StreetPilot c340 GPS Receiver
Can't find satellites
Hello Ray_of_Hope,
In order to get a "fix" on it's current location your GPS needs to download data from three or four GPS satellites. Typically, this should happen in about two minutes or less from the time you first power on the unit. This can take a little bit longer if its been a while since you used the GPS or if you have travelled a long way since you last turned the unit on. Your Garmin Nuvi 200W should be acquiring satellites and providing a location report pretty quickly after power up.
Once thing that can affect the performance is whether not not the GPS has a clear view of the sky. If you are operating indoors, in a car, or anywhere that has a lot of obstructions (in a city with tall buildings or a forested area with a lot of trees) these things can block your GPS's view of the sky and prevent it from receiving data from one or more satellites. This can cause the GPS to be unable to provide a lock on its current location or to take a very long time in locking on.
Best Regards,
Ken
"Go Ahead. Use Us."
May 29, 2008 | Garmin nuvi 200W GPS
Mar 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Forerunner 305 cannot locate satellites
Hey, I install Garmin GPS Chipset Type G and now it seems work well.
Mar 01, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 110 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
