Question about Stihl Garden
Why does the chain brake not work?
The chain brake on my new saw doesn't "click" when you pull it back as described in the manual. Consequently, the chain brake is disengaged permanantly
    Problem Solver:
  • 23 Answers
1. What is the make and model of the saw?
2. Does it make any sound when you push the chainbrake handle towards the front (the bar and chain direction)?
3. The idea, and the way it works is that as the bar and chain get jerked upwards towards your face, your left wrist catches the chainbrake handle and pushes it forward thus engaging the chainbrake.
Posted on Feb 13, 2015
SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
Posted on Dec 31, 2008
  • 17 Answers
SOURCE: Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Posted on Jan 03, 2009
  • 97 Answers
SOURCE: my chain saw stalls when I put the chain brake on.
You may have a broken clutch spring.
Posted on Mar 21, 2009
  • 188 Answers
SOURCE: How do I get chain back on saw? And why does it keep coming off?
Here is a link to instructions on installation of a chain... http://12.153.20.74/manuals/113556-01A.pdf.
Make sure that the chain has been properly tensioned. Sometimes if the guide bar nuts are not tighted securely the bar will notremain in adjustment. Verify that the guide bar bolts are hand tightened plus one full turn with a wrench. If it is has been properly tensioned, the sprocket cover tab (located on the round part of the sprocket cover) may not be inserted into the saw body tab slot. If you are still having problems you just may need a new chain. I suggest that you contact Master Parts at 800-446-1446 or online at www.masterparts.net. If you have the model number they may be able to help you with the owner's manual for your unit also. I hope this helps!
Posted on May 26, 2009
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
Why doesn't brake release?
Hi Gerald,
Maybe the brake is still on.
With the saw OFF, and wearing gloves,
Grab the guard with your left hand and pull it HARD back towards the handle. It should "click" back releasing the chain brake.
Check by seeing if the chain will slide in the bar.
- If it won't release, I would remove the bar, clean all the parts with solvent and air, and then re-assemble it, making sure that all the functions were operating correctly.
Stay happy, chain saws are notoriously reliable and quite straightforward to work on.
Cheers.,
Mar 05, 2016 | Garden
Chainsaw chain sprocket won,t turn
this seems to be a chain brake that's applied , try turning off chain brake by pulling back on hand guard till a click is felt
some folks moving up from an older saw to a more modern saw are not so familiar with chain brakes and don't understand them and how they work
May 25, 2014 | Ryobi Factory Reconditioned 18" 40cc...
New unused chainsaw motor works but chain won't turn
Could be the chainbrake is on, pull the hand guard fully back until the brake clicks off, now try again.
Feb 26, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain not moving on a running chain saw.
Hi. Possibly the chain brake is engaged. It is the thing just in front of the forward handle. Try pulling it back, before starting the saw. It should click into place. This device is supposed to stop the chain in the event of a severe kick-back. If that's not it, you are probably looking at a new clutch or maybe sprocket.
Sep 10, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I remove the chain brake and bar cover from my 51/55 Husquarna saw and cannot get the cover back on the saw. The brake band is to tight to fit over the clutch assembley and I cannot figure out how to get...
Hi, the chain brake has most likely been activated while removing the cover. Place the cover in a vise where the bar nuts tighten up to and pull the chain brake lever backwards towards where the handle bar would be. It should click back and stay back. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Unable to get chain break cover back on after putting on new chain
It sounds like the chainbrake has activated, the band is now smaller that the drum, clamp the brake in a vice, be carfull not to damage the cover, remove the two screws holding the hand guard to the machine and remove, now insert the hand guard into the quadrant in the brake, pull the hand guard fully back to de activate the brake, it will take some force as it is compressing a large internal spring, the other way to do it is to remove the clutch and sprocket, re fit the brake onto the saw and use the hand guard to load the brake, pull it fully back toward the rear of the saw until it clicks and loads, now re fit the clutch and sprocket.
Apr 12, 2011 | Husqvarna 450 e-series 18" Chain Saw
How do i replace my chain on my Partner brake assisted chain saw ?
Make sure the brake is de activated by pulling the hand guard fully back to the top handle, you shpuld hear an audible click when it locks, remove the nuts and side cover, the chain adjuster will either be in the crankcase or the side cover, screw the adjuster right back, remove the old chain, now loop the new chain over the sprocket and lay it into the guide bar with the cutters on the top of the bar facing away from the saw, re fit the side cover making sure the adjuster pawl locates into the adjuster hole in the bar, re fit the bar nuts finger tight, screw the adjuster up so as the chain sits snuggley all around the guide bar, pull the chain around manually with a gloved hand, this will make sure it is properly located in the sprocket and is free in the bar, lift the bar nose and fully tighten the bar nuts
Jan 23, 2011 | Garden
Chain does not rotate around bar. Chain brake seems to engage/disengage as intended.
With a gloved hand can you manually pull the chain around the bar? if not the chainbrake is still engaged, pull the hand guard fully back to the top handle until you hear the click from the brake mechanism, if the chain does pull around manually then there is a problem with either the cluch or the sprocket, remove the side cover, check the clutch for damage, remove the drive sprocket and check the drive teath are not badly worn allowing the chain to slip within it, replace parts as required.
Jan 21, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Iput a new chain on my 350 chainsaw now the cover won't go back on it seem like the brake band won't fit over the clu.
The chain brake is released. try this:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
It requires a fair amount of force. It usually makes a loud click when a keeper engages a detent. Just pull it slowly aft with a little grunt if need be at the rear extreme. HTH
Lou
Feb 04, 2010 | Husqvarna Garden
Ryobi pcn 4040 chain saw
I have the same model chainsaw with the same fault. The brake is not releasing when the brake handle is pulled right back. I can only run mine if the brake handle is pulled back to the main handle with a tyrap - defeats the object of the auto-brake completely. Design fault I reckon.
Sep 28, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
88 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
