Question about Ace Hardware AMERICAN TACK 3236858 SCREW-IN PROGRAMMABLE LIGHT CONTROL 100W
How to set ingraham timer model 12-010 - Ace Hardware AMERICAN TACK 3236858 SCREW-IN PROGRAMMABLE LIGHT CONTROL 100W
I have two Intermatic wall switch timers: Easy set timer model SS7 and one with number 154ST24898. Any idea ho to program these?
Crystal Air ozone machine support
https://www.bing.com/images/search?q=easy+set+timer+model+154st24898&qpvt=Easy+set+timer+model+154ST24898&qpvt=Easy+set+timer+model+154ST24898&qpvt=Easy+set+timer+model+154ST24898&FORM=IQFRML
Nov 13, 2016 | Intermatic Hardware & Accessories
Need instructions for Ingraham Model 12-806 timer
That model timer is not identified at Ingram.
Copy following links:
http://www.ingramproducts.com/Timers-Analog_Timers.html
http://www.ingramproducts.com/Timers-Digital_Timers.html
Add a comment and describe the timer in detail for more help.
Sep 18, 2012 | Hardware & Accessories
I have an Ingraham Model 12-830 350 timer which will not turn on the light. I can set the times and the redlight comes on but the light does not go on.
Turn on the light, and check bulb:
Copy following link for general instructions and troubleshoot
http://waterheatertimer.org/How-to-set-timers.html
Jul 16, 2012 | Salton Ingraham Single Program Timer
I do not know how to set it. i have lost the instructions for a 111woods model tn300
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Open following link for instructions how to set analog timers.
Sep 02, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
OUTSIDE FLOOD LIGHTS HAVE BEEN ON FOR 2 DAYS. IS THE SOLAR CELL TIMER BROKEN? HOW DO I TURN LIGHTS OFF?
I cannot find a manual on this timer.
If I was at your house, I would try the following:
1) Read the manual troubleshooting section
2) Check for dirt over the sensor
3) Turn off the circuit breaker to timer/ or unplug from wall
4) Re-power timer and then Re-program timer
5) If these steps don't work, the timer may have gone bad
And lastly, since many people do not have the manual, press it flat in a book for two days, scan it just like you scan a photograph or have Office Depot scan it onto a disk. Load photo of manual onto Imgur or Flikr photo-sharing and then post that link in a fixya question so others can see the manual
Oct 05, 2010 | Solar Ingraham 20 Program Electronic Timer...
Lost instructions for TE 109
1. Press and hold SET until day flashes. Use arrow keys to set
2. Press SET again and hour should flash. Use arrow keys
3. Press SET again and minutes should flash. Use arrow keys
4, Press SET again to exit time-set mode.
Sep 25, 2009 | Solar Ingraham 20 Program Electronic Timer...
Need instructions for Ingraham model TE109
To set the timer press the right arrow key.
The timer will now be blinking 1on.
This means on time for program 1.
Press set.
The days of the week will be blinking now.
Use the arrow keys to scroll through the options, like
just one day of week, every other day ETC..
Press set when you get what you want on the days.
Now the hours will be blinking.
They start at 12:00 AM, so to go to 1:00 PM you would have to
press the arrow key 13 times.
When you get the correct hour, press set.
Now the minutes will be blinking.
Choose the minutes you want with the arrow keys and press set.
You will be back to 1on blinking.
Now press the right arrow key to go to program 1 off.
Set the off time the same way you set the on time.
After setting the off time, or any time 1off is blinking, by pressing the right arrow key you will go to 2on and so on.
You can scroll through all the programs by continuing to press the right arrow key.
Both arrow keys work i.e. you can go backwards if you went too far.
You can go to program 20 off if you press the left arrow key.
Keep pressing the left or right arrow keys to skip to the program
you want to change.
When you get to the program you want to change, press set
Mar 27, 2009 | Solar Ingraham 20 Program Electronic Timer...
Can't find instructions
email me at rlehman123@comcast.net for a copy of the instructions
Feb 10, 2009 | Solar Ingraham 20 Program Electronic Timer...
Ace Hardware AMERICAN TACK  3236858 SCREW-IN PROGRAMMABLE LIGHT CONTROL 100W Logo
60 people viewed this question
Top Ace Hardware Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Ace Hardware Hardware and Accessory Expert? Answer questions, earn points and help others
