Question about HP Computers & Internet
0x0000007f error I did a disk clean up and deleted my hibernation file...normally when I do this I just type in power/cfg hibernation on...but it's not working. The message "error 0x000007f" keeps coming up. Any suggestions?
    Habit-Forming:
    Scholar:
  • 71 Answers
5 Suggested Answers
ziraffa
  • 827 Answers
SOURCE: How do I delete an
Hi Barry,
Right-click on the file icon and in menu select "Open with..". Select Notepad as program to use.. It should return the following error.. "This file does not exist......would you like to create a new one?". Click on "Yes" and you'll get a blank Notepad screen, type some text and then save the data.. You now have a working file with data in it which you can delete.
Hope this helps
Chris (ziraffa)
Posted on Dec 27, 2008
ziraffa
  • 827 Answers
SOURCE: Cannot delete file
Try this file called "Unlocker" - http://majorgeeks.com/download.php?det=4660
If that doesn't work, give "Pocket Kill Box" a shot: http://majorgeeks.com/download.php?det=4709
  • 956 Answers
SOURCE: 4.0 GB of Spyware errors taking up space in my computer
Yes! it is the log of previous antispy ware scans.
Posted on Nov 14, 2009
Testimonial: "Thank you, made an immediate positive change to my computer speed!"
  • 8 Answers
SOURCE: WINDOWS ERROR MESSAGE
boot from the CD copy of your windows XP. enter in console session and manually replace the file. if the file is corrupted this should fix it
Posted on Feb 28, 2012
Too slow,how can i speed it up
How to Make Windows XP Startup Faster
Steps
1.Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
2.Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
3.Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
4.Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
5.Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation
After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally. However, Hibernation is a good long-term solution, as it does not waste electricity.
1.Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
2.Click on the box that says "Enable hibernation" to check it.
3.Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
4.Restart your computer every week or so to clear your computer.
The power can then be completely turned off, even at the socket so that no power is wasted.
Prefetch
1.Simply browse to the windows folder (Ex: C:Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:windowsprefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementPrefetchParameters
Under this key you should see a value named: EnablePrefetcher
It has 4 possible values:
0- Disabled : The prefetch system is turned off.
1- Application : The prefetch only caches applications.
2- Boot : The prefetch only caches boot system files.
3- All : The prefetch caches boot, and application files.
We don't want to disable it entirely. This would actually make boot times *longer*. This is because this feature is also used to speed up the loading of boot files. That is why we are going to pick the number 2 option. It allows us to keep the advantage of caching system files, without continually clogging the system up with applications.
Set the value to 2 and reboot.
The 2nd time you boot it should boot much faster. Remember that the side effect is that launching individual applications once windows has loaded will now be slightly slower.
Tips
When installing new software choose not to add the program to the startup folder.
. Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
. If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
. Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
. uncheck system startup unnecessary startup programs*
Warnings
. Save any open work before making changes.
. Shut down all applications before making changes.
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.
Apr 09, 2012 | Computers & Internet
Tip
How to Make Windows XP Startup Faster Steps 1.Click on Start, then Run, and type...
Steps
Hibernation
Prefetch
Tips
Warnings
on Feb 25, 2011 | Computers & Internet
How do you clean a laptop ram?
Hi there loverboyjero! :) here are the steps on how to clean a laptop ram :)
1.Log onto your laptop and click "Start." Go to the "Control Panel." Choose "Performance Information and Tools." The window lists data information such as calculations per second and memory operations per second. On the left is a list of tools for disk cleanup. The tools in this window can also be accessed in the "System Tools" folder inside "Accessories," which is also located at the "Start" menu.
2.Click on "Advanced tools." Choose "Open Disk Defragmenter." The window will list the last time the laptop was defragmented. If the "Last run" was over a month ago, click "Defragment now." Defragmenting your hard drive will rearrange files so that the laptop can better access them. Defragmenting may take an hour or longer, depending on the last time it was done.
3.Click back to return to "Performance Information and Tools." Click "Open Disk Cleanup." The window will prompt you to select a drive to cleanup. Select "C:" and if you have more than one hard drive, an external or a partitioned hard drive, do a disk cleanup of these drives as well. Wait for Disk Cleanup to calculate how much space you will be able to free up. This may take a few minutes to complete.
4.Select the items that you want to delete. These files will be permanently deleted. Delete "Temporary Internet Files," "Downloaded Program Files," and the "Recycle Bin." You may have an option that says "Hibernation File Cleaner." Removing this file will disable hibernation on your laptop. Do not remove this file if you use hibernation. Click "OK," then "Delete Files.
Sep 30, 2011 | Computers & Internet
Can I increase disk space for Presario F762NR notebook? And if so..how. Thank-you
You can compress the disk and gain a little room which might meet your needs, otherwise you can buy a new disk and install it. I have cloned many laptop disk drives onto new ones. It does take some special cables and and a desktop computer to do however.
Before I do either, I'd try a disk clean up. Turn system restore off then back on to delete all the SR files. Down load CCleaner and run it against the disk and run the registry cleaner.
http://www.piriform.com/ccleaner/download
Disable Hibernation and delete Hiberfil.sys, if the space problem is critical on your System Drive. Its a hidden file on the root directory of your system drive. Open Control Panel. Type Hibernate in the search bar. Select turn Hibernate On / Off.
If you want to try the compress, double click My Computer, right click on the C:\drive, PROPERTIES, check Compress this drive.. This will take awhile so don't turn off the computer or let it shut down. Some say you should not compress the windows folder but I've never had a problem and they slow down is almost not noticable.
Aug 04, 2010 | HP Compaq Presario F762NR Notebook
My laptop was on hibernation. now it is not booting. please help
Hibernation is enabled by default in Windows Vista, and is one of the seven options (i.e. Hibernate) that appears on the Vista shutdown menu. Hibernate your Vista system will enable you to quickly restore to existing system state and intact workspace instead of start afresh, run programs and open your documents one by one again. If you do not use the hibernate feature in Vista, and want to delete hiberfil.sys and then recover the space occupied by the big hibernation storage file, the hibernation function can be turned off and disabled.
Unlike Windows XP, users cannot turn the hibernation on or off via Vista GUI interface anymore. Previously users can enable or disable hibernation via Power Options applet in Control Panel. This option no longer available in Windows Vista, which also enables Hibernate ability and creates hiberfil.sys by default. Instead, users have to rely on command line utility Powercf and Disk Cleanup Wizard to disable hibernation in Vista. Microsoft KB920730 provides details on how to disable and turn off hibernation on computer running Vista system. You must log on to Vista with user account in Administrators group to perform these action.
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
If you are prompted by User Account Control for permission, click Continue.
At the command prompt, type the following command, and then press ENTER:
powercfg.exe -h off
Type exit, and then press ENTER.
Another easier workaround for those who’re not comfortable to work with command line is to disable hibernation and hybrid sleep feature in Windows Vista is by using Disk Cleanup wizard tool, the built-in Windows disk cleaner to delete hiberfil.sys file. The hibernation file must be enabled to access the hybrid sleep feature and the hibernation feature in Windows Vista.
Click Start button, then go to All Programs -> Accessories -> System Tools, and run Disk Cleanup.
Choose which files to clean up, either My files only or Files from all users on this computer is fine.
On “Drive Selection”, select the Windows Vista boot drive to clean up. Note that you must select the drive where Vista is installed, which normally is also the boot drive (C:) as hiberfil.sys file will be located on the root folder of it.
Once Disk Cleanup finishes scanning the system, Disk Cleanup for Vista window will open.
Select and tick the check box next to the Hibernation File Cleaner.
You can select or deselect other type files to clean or preserve from the available items or options in the list provided.
Click OK button when done.
Hibernation will now be removed and disabled.
It will solve your problem.
Dec 28, 2009 | HP Compaq Presario V3000T Notebook
The option for hibernating just disappeared. Somebody told me that it had to do with the video card. I have an hp Pavilion dv2000,Vista OS. I can't find the drivers for the video card, so I can't reinstall...
the disk clean up in vista will have included a large file for hibernate file cleaner if selected to be removed hibernate is disabled
re-enable hibernate if this has happened:
How to enable hibernate option in windows vista for those of you who mistakenly deleted your hibernation file using disk clean up, to re-enable your deleted hibernation file, click the start menu and then go to all programs - accessories - Command Prompt. Right-click command prompt and select "run as administrator".
When Command prompt has opened, enter the following
powercfg /hibernate on (note the space between powercfg and /) so it's not powercfg/hibernate on or powercfg/hibernateon it is powercfg /hibernate on
This should re-enable hibernation
May 12, 2009 | HP Pavilion dv2000t Notebook
Computer is not starting up in standard windows mode. dell media keeps popping up and when i exit the program my pc shuts down. i tried ctrl and f8 it brings me to a short menu. (1) continue restart...
Are you running Window XP? Is your computer set to hibernate? If so, you may have a hibernation error...
If I understand correctly, while pressing F8 during bootup you received a message that states:
"System restart has been paused:
Continue with system restart.
Delete restoration data and proceed to system boot menu"
You may wish to read this article about the error. http://support.microsoft.com/kb/294427
Then, go ahead and do that second option. What hibernate does is write a big file to the HD with the exact state of Windows. That is a "restoration" file. If hibernate doesn't work, deleting the restoration file will often allow the computer to restart normally.
Good luck! Please post back with your results.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | Dell Inspiron 1420 Notebook
Operating system
If you have a laptop, it has a function called Hibernate. In this, the entire thing that is running, as it is in the RAM, is stored in a place on your hard disk and the PC is shut down. It resumes everything when it is switched on later.
The place reserved on the hard disk is a small thing called 'hibernation.sys' and it is as big as your RAM. If you don't need it, you can delete it through the command line or Disk Cleanup.
Now, the problem you are in is that the file has been deleted, mostly through cleanup and the system cannot hibernate anymore. I recommend that you use System Restore and roll back the computer to when there wasn't any problem. This won't harm your personal files. Now, remember to uncheck 'Hibernation Files' or similar in Disk Cleanup to avoid deleting it.
Or else, there is another way to restore the file without using the time consuming System Restore. See this.
Dec 13, 2008 | Computers & Internet
Hibernate configuration with windows authentication
When you login to your database (download the management tool) right click on server name->properties->security.
There you can choose mixed authentication.
Sep 05, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
