Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio washer is leaking water
I think the error code was LF but not sure. The washer has been leaking water all over the floor.
  • knb4evr Jun 23, 2009
    We've had the washer for over 3 years! My husband just took the washer apart and found a hole in one of the motor casings (?). He's going to try and gorilla glue it and/or JB Weld it.
  • 39 Answers
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Posted on Jun 23, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Error code LF means Long Fill. If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jun 23, 2009
    Thats really nice that you found the error however my reply was for the question that you posted i.e. LF error so I believe this should not be a Inapporpriate answer. Please do change the rating.
    Thanks
    Rylee
    New Friend:
Boulden is correct at least in my scenario ours is only a couple months old and did the same thing i checked the drain hose and low and behold it was shoved all the way down to the trap i adjusted it and it is now working just fine
Posted on Apr 02, 2013
My cabrio whirlpool washer automatically restart new wash
Well, is it LT, or LF? They mean completely different things.
Jul 16, 2016 | Whirlpool Washing Machines
What does LF mean
LF generally means "long fill error," which is generated when your washer is not getting the correct amount of water. This could be because of a clogged inlet screen, a leak which is causing low water pressure or a faulty inlet valve. You may want to contact Whirlpool for instructions on checking or replacing your hose, or cleaning the inlet screen.
Jun 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
What is the LF Code my washer puts out
Hi Sherry,
The code definition for LF is a LONG Fill (F30). What does that mean is the next question? Here goes.
a. The fill hose may have a pinch or fold between the connections on the pressure in .
b. Are the hose screens plugged at the connections.
c. Is the water siphoning out of the drain hose ?
d. Is the water pressure at peak, check valve, filters before washer.
Now if your savvy hungry. Here is a learning curve link
Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis .
Okay. The next link is for the manual for your favorite machine. Manuals and Troubleshooting Whirlpool Whirlpool Cabrio Washer Fault Codes . I tried this and you need registration.
I decided to go one step further and track down a printable and savable resource for you. Yes, all, the fault codes and what they mean.
I did pretty good from memory but that link leads you to a printout you can keep right by your washer. Most of the occurrences are easy to fix without a technician. Hope this makes your day. Better. Fare. Well.
Jun 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What does whirlpool duet error code lf?
Lf or long fill could be a multitude of many. Is the water turned on, is the hoses kinked , the water inlet screen clogged, water lines crossed, bad or faulty water inlet valve, or faulty pressure switch.
May 01, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
I have a whirlpool Cabrio, what does LF error code mean and how do i fix it??
The LF error is a water supply fault. Both water supplies must be connected and fully opened. The inlet hoses and valves both have strainers that may need cleaning as this could obstruct the water flow and also check that you don't have any water leaks. The unit requires a minimum water pressure to operate so anything that could prevent the unit getting this pressure will cause this fault. Hope this helps you out!
Nov 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer
Sounds like a control board problem
Nov 11, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Overfilling Whirlpool cabrio washer
Great! It may be the water level control switch. So, where is it and how do you check it or fix it or replace it?
Jan 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,697 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
